Best hardware to run HA on in 2023?
I’ll be moving to a new house next year. A good moment to start with a fresh install of HA on new hardware. What’s the best hardware to run HA on these days? I have been running HA on a Raspberry Pi 2 for years now. It’s still running fine, although it is noticeable that this is not the fastest hardware around.
I have the following requirements:
  • Low energy usage
  • Passive cooling
  • Good performance (good is good enough, anything that is faster than RPi 2 will be fine, I guess :wink: )
  • Wired Ethernet (will be installed close to internet modem and switch)
  • I already have the Sonoff Zigbee 3.0 dongle, so built-in Zigbee support is not needed.
  • Nice to have: Power over Ethernet
  • Not too expensive
  • Available from a European reseller
Seems to be A Home Assistant Yellow profile… Home Assistant Yellow Guide
In the Netherlands, HA Shop has some options preconfigured. For example: HAshop Intel MiniPC Celeron Compact met Home Assistant passief gekoeld - HAshop.nl
Odroid C4 might be an option
The example you link to is an Intel-based machine. Don’t you expect compatibility problems? It seems to me that most HA installs use Arm64 architecture hardware, like the Raspberry family.
That sounds nice. Affordable, comparable to Raspberry Pi4, eMMC storage and good availability.
What’s best for me, might not be the best for you.
A used HP Prodesk G4 mini was the best solution for me :-). This will cost you perhaps 200€ used. Ok no passive cooling, but it is barely recognizable, idle power is ~4-5W with i5-8500 CPU.
afbeelding
According to this graph and your opinion there must be a rain of complaints about compatibility… :wink:
But there is not.
HA is super-stable on intel, maybe even more stable, than on Arm. :stuck_out_tongue:
I do use passive cooled intel based SFF PC from Shuttle. Designed to run 24/7. That was a gold shot. The love between this machine and HA is there… :wink:
Not really. Lots of folks around here run on x86.
As a pure python app, HA itself is about as platform agnostic as is possible. I can’t imagine x86 HAOS support being dropped, I doubt the community would allow it.
ARM’s historical advantage for HA has been price more than anything else. That price advantage can start to evaporate if you want a fully configured system with more ram, a case, power supply and (non-USB) ssd capability.
The ARM SBCs still generally have a power advantage, the importance of which can vary based on theology and local costs.
Thanks @BebeMischa and @jerrm, that’s really useful information!
To be prepared for the future i took a nuc (8th gen) and a passive case for it (something like this ). It not the smallest one (and you will loose wifi), but it’s absolutely silent and does it’s work.
Before 2022.11 it was about 3W, now it’s about 5W. But it’s not the cheapest solution.
And to clarify, both the “Generic x86-64” and “Virtual Machine” are x86 images.
I can confirm - HA (in my case HA:OS) is running fine on my intel based machine :slight_smile:
You have pretty clear requirements (fanless, low energy profile, etc.)
But my recommendation would be, to cross check, what else might come in the near future.
I’ve decided to build a small “home Server” - which is able to run other Systems as well (virtualized / containers) - rather than setting up several “Pies” or other small hardware for the different tasks.
So I can “somehow” combine a storage, smarthome (HomeAssistant), my HomeMatic CCU, Media Server etc. in one machine… sure… It does require more energy - but I don’t know if running 5 or more Rasspberry Pies + NAS, or whatever else is really saving that much energy ^^
So - just consider upgrade options for the (near) future - especially, when you do have the options to plan network and so
Thanks. I have different considerations:
  • I already have a Synology NAS running. No need to replace it. I use that for all office- and multimedia related stuff.
  • So the new device will be dedicated for all things home automation.
  • It seems RPi4 or Odroid C4 are powerful enough for my use case and any future developments. (I’m still running HA on a RPi 2 today…)
  • Low power consumption is really important. Not only because of costs, but also to minimize CO2 emissions.
So, I’m leaning towards a RPi4 or Odroid C4 for now. I’ll keep an eye on the market; I still have a couple of months to go.
For most “just HA” installs an 8th gen nuc is at a different level. Sort of like taking a Ferrari to a go cart race.
But I virtualize everything. Other than desktops and hypervisors, I haven’t run anything on x86 bare metal in over 15 years.
I own RPi zero W, Rpi 3, Rpi 4, Odroid-xu4 and Odroid-C4 and the C4 is my favorite by far. I think raspberry pi is overrated. It is like the arduino of the microcomputers. Ubiquitous because they were the first in their market but nowadays bad relation quality/price.
It is just a personal opinion.
Two recent links from another thread for you:
https://www.ebay.com/itm/363975406150
Thanks, @FredTheFrog !
Personally, I’d like my setup to be as simple as possible. The less moving parts, the less potential errors…
So for running “just” HA in the preferred “supervised” setup, I guess a RPi4 or Odroid C4 is good enough. And probably offers the most easy and straightforward installation and maintenance.
Why don’t you run HA on your NAS?
A lot of people, me included, run HA virtualized or as container on Synology.
Good question! I don’t have good experiences with running virtualized things on my NAS. I had the controller for my WiFi network running as a Docker container, but it was unstable. Since I switched to a dedicated hardware controller, the WiFi network is much more stable.
My UniFi Controller runs without issue in Docker. Containers you can download are not always official releases and might therefor lack in stability. That’s not necessarily the fault of Synology or Docker.
Mount the HA OS image in Virtual Macine Manager and test it. I never had any stability issues. Advantage is that you can automatically make snapshots and restore your whole setup if something goes wrong.
