Best Home Assistant OS Installation Options Without Docker for Dedicated Hardware
I’m setting up Home Assistant and looking for the best OS installation option. I don’t want to use Docker, as I’ll be using dedicated hardware and software. What are the best installation methods to consider for Home Assistant, especially for a more stable, dedicated setup?
A mini PC running proxmox (os) then haos as a VM, is a fairly popular route and pretty solid.
Or… you can put haos on the same machine bare metal if you prefer
But either way best bang for the buck in late 2024 is a miniPC…
