Hi, I’m currently planning my move from RPi3 to NUC with Hass.io.
I have read a lot of threads in this community, reddit and others… however I’m still unsure about the HostOS to use for my NUC Adventure.
Can you recommend some OS over others? If so, why?
So far i have found 4 good ways:
Core OS -> Docker Hass.io — Core OS seems to have automatic updates for security in the background Ubuntu -> Docker Hass.io — Ubuntu seems to be most used one, easy for beginners Debian -> Docker Hass.io — Similar to Ubuntu but maybe a bit more light weight? Proxmox -> Debian VM -> Docker Hass.io — Seems to be necessary to run an extra VM if one wants to use Docker with Proxmox. Appears to be very stable.
My requirements are currently very basic… I’d like to use Hass.io with all the Addons as before. On Top i’d like to run my Plex Server as Docker container and maybe some other containers in the future. It will be headless but it would be nice to have some GUI for remote managing…
Basic server management(add, delete user, setup ssh keys,etc)
It is basic toolset. I use cli mostly but it helps when I cannot figure out why container won’t start (live logs are helpful here) or quick look at what’s happening on server.
It was lightweight and not seem risky app so I use. Originally I tried things like freenas and omv but liked basic Linux best as GUI always suck in the end vs cli. Cockpit can manage multiple server in single ui so this worked well in my planned environment (app server, nvr, and need basic overview and control). I would never expose this outside of network but same is true for ssh.
Sorry for reviving a topic so old, but the contents of this apply to basically any x86_64 system so it’s still relevant.
I’ve sinced switched from unraid to basically what @tmjpugh was describing.
Ubuntu with Cockpit and Docker(-Compose)
BTRFS on everything except for ext4 dockerappdata&database SSD.
nvme boot ssd
multiple HDD’s pooled with MergerFS (on top of single BTRFS snapshots) and protected to failure with (btrfs-)Snapraid.
all scheduled to do regular tasks (backups/maintenance/scrubs/snapshots/etc) with systemd timers.
Cockpit backports is usually most recent version.must also install the other things like cockpit-storage/backports and other packages. I don’t use network-manager so only allows monitor general throughput not manage ethernet
I use portainer as well for updating images. I don’t use “latest” images and prefer install specific versions instead
