Best installation device
I went through a lot of documents on how to install home assistant and where to install it.
Right now it’s running as a VM on hyper-v , I was thinking to move it to wither a raspberry pi 4 (I have one for that) or to an old computer with an i7 processor. The reason I want to move it is because I want to be able to use usb dongles for zigbee and zwave, and as you may know hyper-v doesn’t support that.
My question is it worth it to install it on the old i7 computer? Or raspberry pi 4 is enough? I don’t want to struggle with performance, but I don’t want to have something overkill either.
From what I’ve read, if you install it on your own on a computer, you will have to deal yourself with all packages install and update, while on a raspberry pi it’s all handled by the image.
Any insight or help is appreciated.
Hi @Pedro1x, I’m running mine in a container (LXC/Proxmox) with 2 cores and 512Mb but I don’t have that much devices/entities/automations yet so the load is very low.
I would think that an i7 would be serious overkill and advice you to try out your RPi.
The only thing there is the SD card <=> possible corruption, which you can avoid by using a SSD.
Just my 2c…
Im running HA supervised in Docker on Debian 10.
On this machine: Shuttle Global - XS36V4
with 4 GB RAM and 120GB SSD.
It is a low energy, very stable and fast setup. The system uses very little of the available resources.
Updating is a piece of cake, all done thru the HA UI.
Thanks guys for your answers.
So in theory I could install debian and run home assistant in a docker.
Would I be able to use usb dongles through the docker?
Why move it? If you want the experience of the image run Home Assistant Supervised on a Debian VM.
Hyper-v doesn’t support usb passthrough, so can’t use dongle.
I missed that detail in your original post
I am using Hyper-V with a usb dongle for Z-Wave. The server sees it using the Windows drivers for the stick and the resulting COM port is mapped to a Hyper-V VM.
I couldn’f find a way to map that. But I wanted also remove some load off the server.
The setup i did describe works with USB Z-wave stick flawlessly…
I am really interested how you managed that? It’s a known fact hyper-v doesn’t work with dongle unless you use a third party software for a usb redirection.
I do not run VM. I run HA supervised in Docker on Debian.
I have a dedicated RaspPi 4, 8GB with a 120 SSD that works great, with 35 plus Zigbee devices (using a Nortek dongle) as well as a similar qty of Kasa Wifi lights, dimmers and switches plus misc devices like my iRobot, Door Lock and thermostat. I use Node-red for all my automations and everything runs great. I did run on a NUC for a bit (Celeron processor) and it also ran well but that seemed to be overkill, even with a Celeron processor.
So from all your answers, if I have a raspberry pi 4 with an ssd , that would be enough for most scenarios. Right?
I’m running HA on a NUC11 with Proxmox as virtualization. It works great.
Based on my experience, yes. It works great. I have read that the SATA to USB cable can make a difference but so far I have not had any issues.
