The hikvisioncam switch device added via configuration.yaml does nothing, the above URL gives 403 forbidden or blank image if I add a generic camera, ONVIF device only displays the primary stream which is too detailed and slow for any decent use, plus it’s stream is constantly used by the NVR.
Is there any other way that I can have the second low-res 320x240 stream up on lovelace at a decent framerate?
If you use the low-res stream with the generic camera then that’s likely your simplest option - it’s exactly what I do, using that RTSP h.264 feed.
I do not have YAML configuration, since 2022.04. It was moved to GUI.
The user is created directly on the camera. I just called the user for “HA” to remember it easily. It is a Hikvision camera
The feed is shown in Lovelace using the Picture Clance card. It works with both the high-res and low res. The highres on channel 101, the lowres on 102
It works using Nabu Casa access from remote sites.
Here is screenshot of the configuration from GUI (if you know how to access it in YAML I will copy it)
I’m using 2022.00 - Will upgrade now - this may be why my setup isn’t working - Will upgrade and test then let you know - Thanks for the help with this
