Best option for creating a graph like the energy dashboard
I want to create a graph with the same options as the energy dashboard to track the hours of activation of my boiler.
Functionalities:
  • Buttom to select the range of timeto be visualizad : 1d, 7d, 1M, 6M , 1y
  • Changing the period of each bar according to the rage of time: 1D–> hour, 7d,1M–>day, 6M–>1y: Month
something like this but simpier, with 5 buttons to select predefined time ranges:
SO far I have tried wiht plotly graphs, but is not working properly , as explined in this other topic:
I have also checked appexchart but I didn’t find any option to dinamically change the time range and period of a bar graphs.
It seems very strange not having this option natively in HA , as it’s working in the energy dashboard but , does anybody how to do a graph like that?
You can use the energy dashboard cards in your own dashboards, including the date picker.
Thanks, but one question. I want to use this graph to track the unit “h”, that is how I’m tracking my heating system consumption. Is it possible to configure these graphs with a measurement with h units? I thought you could only use kWh or energy units.
Ok, I just checked your proposed solution and that cards are just a replic of the energy dashboard card. You can not configure them for another entity, indeed they don’t even have a config option, they use the same entities as the dashboard, so it’s not a solution for my problem.
Maybe this is an option
I’m looking to do the same for my GSHP. Did you ever find a solution?
No sorry, I abandoned this idea but if you find any solution, please post it here
There is a new feature of statistics-graph-card that allows it to follow the energy-date-selection card.
So if you can fit your data into a statistics graph, you can have dynamically selectable ranges.
