I have HASS.IO up and running on my secondary Pi. I’d appreciate help from the community on what the best practice is to get all of my old data/config files (from HASSBIAN) to HASS.IO.
What folders/files do I need to bring over where do we put them?
Copy over configs without any changes except for removing the lines for SSL keys.
Set up duckdns and letsencrypt via the hass.io interface, then put the ssl changes in my config.
That’s it. I had some mqtt stuff set up but it had been broken for a few weeks. I installed mosquitto and fixed all those things up. Everything else I didn’t have to change. I’ve got my pi plugged in to ethernet and assigned a static IP via the router, and that all worked perfectly.
Was your letsencrypt/SSL setup the standard setup which uses port 80? I had to use the alternative method which uses a different command to generate the letsencrypt certificate since I can only use port 443 externally.
Honestly I’m not entirely sure. There’s two options, one which is HTTPS and another which is HTTP. I assumed it was only using 443, but it was giving me a hard time about not being able to bind to 80. If you have to use a workaround you will probably have a problem using the built in tool.
I moved from my Mac mini to hass.io on a pi3. Literally just copied across the yaml files and custom components folder onto the pi, added hassio: to configuration.yaml and checked for any references to the Mac’s ip.
Any tips on how to move my current ssl certificate over to hass io?
The only thing holding me back from moving is the ssl stuff, just started using home assistant two weeks back and setting up the ssl certificate stuff was by far the hardest part.
Probably, the reason i ask is because i have Several tasks setup in tasker and ifttt that make api calls to the https address i am currently using. Making a new certificate would mean changing all the applets/task
Is setting up sensors and things in hassio the same as regular homeassistant… I’m wanting to create a custom python script to get more info out of my place server to trigger automations.
I am also considering moving from hassbian (virtualenv) to hass.io because of Deprecating Python 3.4 support - Home Assistant.
I think what it will be easy to copy over all HASS config files, but what about homegear und zwave stuff? How to transfer that stuff?
TIA
