i have a lot of lights that turn on using a motion sensor. The same lights schould also turn on with a Button - but with different settings (e.g. 10% brightness on Motion and 100% on Buttonklick).
How do i make shure that if the light is turned on via Button the motion sensor is ignored?
I just switcht to Home Assistant after using some other system for 5+ Years …
Bear in mind, I’m 6 months or so experienced with HA. Templates probably could make this chore simpler [sic], but I’m not ‘there’ yet. What I’d do today for something like this, with the UI alone, is to start with a new automation and set up 4 triggers:
Trigger: Button status on (assign a trigger ID, like “button-on”)
Trigger: Button status off (assign a different trigger ID, like "button-off)
Trigger: Motion (or Occupancy) detected (assign another unique trigger ID )
Trigger: Motion (or Occupancy) cleared (assign one more unique trigger ID )
Add a CHOOSE Building Block in the THEN DO section. For each Choose Option have a trigger ID (determined above) be the trigger for the actions to be performed
Option 1. Button ON trigger ID
- call a SERVICE to disable motion automation (or disable device if an automation isn’t used)
- turn on lights at determined brightness
Option 2. Button OFF trigger ID
- turn off light
- call a SERVICE to enable motion automation
Option 3. Motion triggered
Option 4. Motion cleared
- turn off lights
I’m also interested in what others would suggest, I’m still learning a lot through both head-banging by myself as well as what I glean from others more experienced here. f
