I am simply swapping TPLINK plugs for two devices. What is the best way to do this without making a mess of things?
One is a lamp and the other is a 3D Printer - I am swapping the two.
So you are saying you are just switching which of two existing plugs controls which device?
if so then just rename one of the two plugs to a temporary entity_id, then change the entity_id of the second to the old entity_id of the first then change the entity_id of the first to the old entity_id of the second.
Friendly names don’t matter. You can have two things with the same friendly names. just the entity_ids need to be unique.
After the entity_ids are re-configured then you can change the friendly names to whatever you want. Or even at the same time. It doesn’t matter.
Thanks so much! Just better to be on the safe side. : )
