Juve_A
January 21, 2021, 9:52am
1
First of all, thanks to the community for this great tool and the vast information you provide.
I’m fairly new to HA. I’ve set up a simple automation for the heating of my kids room, but I’m unsure if there is a better way to do it. Currently I’ve two automations (on/off) to turn a switch on/off based on a temperature sensor as follows,
- id: Calefaccion_on
alias: Calefaccion On
- platform: time_pattern
minutes: '/15'
condition:
condition: and
conditions:
- condition: time
after: '22:45:00'
before: '07:30:00'
- condition: numeric_state
entity_id: sensor.temperature_1
below: 21
- service: switch.turn_on
entity_id: switch.calefaccion_1
- id: Calefaccion_off
alias: Calefaccion Off
minutes: '/15'
condition:
condition: and
conditions:
- condition: time
after: '23:00:00'
before: '07:30:00'
above: 22
- service: switch.turn_off
So, it checks every 15 minutes whether the temperature is above or below the limit, during night time. To me it looks like a bit redundant. Would it be better just to use the numeric_state
as the trigger? Is there a better way to do it?
Thank you.
tom_l
January 21, 2021, 9:59am
2
Yes it would, but with a couple of extra triggers:
- platform: numeric_state
below: 21
- platform: time
at: '22:45:01'
condition:
- condition: time
after: '22:45:00'
before: '07:30:00'
Note the second time trigger in the on automation to ensure the heater turns on if it is already below 21° when the time window starts.
above: 22
- platform: time
at: '07:29:58'
condition:
- condition: time
after: '23:00:00'
before: '07:30:00'
Note the second time trigger in the off automation to ensure the heater turns off at 07:30, even if it is above 22°.
Juve_A
January 21, 2021, 10:29am
3
Thank you @tom_l . Does that mean that both triggers have to be true?
tom_l
January 21, 2021, 10:33am
4
No, multiple triggers are OR.
When any of the automation’s triggers becomes true (trigger fires ), Home Assistant will validate the conditions , if any, and call the action .
Automation Trigger - Home Assistant
stryker
(jonathan spooner)
January 21, 2021, 11:10am
5
When your feeling brave take a look at the generic thermostat component in HA (https://www.home-assistant.io/integrations/generic_thermostat/ )
It shows just like any thermostat control in your lovelace dashboard… you can also control it with google home speakers if you have that all set up too. Essentially it’d save you running the automation with a static temperature to work to
m0wlheld
(Christoph Dahlen)
January 21, 2021, 11:17am
6
How about
- id: Calefaccion_Control
alias: Calefaccion Control
below: 21
above: 22
condition:
- condition: or
conditions:
- condition: time
after: '23:00:00'
before: '07:30:00'
above: 22
- service: >-
switch.turn_{{ 'on' if states('sensor.temperature_1') < 21 else 'off'}}
will switch on the heater during the night, if required
will switch off the heater anytime, if temperatur is above threshold.
tom_l
January 21, 2021, 11:55am
7
Not if the the temperature is already below 21 when 11pm comes around. That is the reason for my extra triggers.
Much better to set up a generic thermostat, then have an automation set the target temp depending on time
Juve_A
January 21, 2021, 1:53pm
10
Thank you all for your suggestions.
@tom_l , just to clarify, the first automation turns on the heater at the trigger time regardless the current temp, and if it is above threshold the second automation turns it off?
@samnewman86 Just for fun I’m trying your suggestion and it seems to work just fine.
I will try both and decide which one I keep as solution.
Thank you all!
tom_l
January 21, 2021, 1:58pm
11
Juve_A:
Oh yeah. Crap. You need another condition to prevent that happening:
below: 21
- platform: time
at: '22:45:01'
condition:
condition: and
conditions:
- condition: time
after: '22:45:00'
before: '07:30:00'
below: 21
TBH I reckon the scheduled generic thermostat is the more elegant solution. Nicer interface for adjusting the set-point too (thermostat card ).
