Best RGB Bulbs of 2021?
So considering the microchip shortage and supply chain disruptions over all what are our best options for RGB bulbs for 2021?
I would prefer a z-wave RGB so I can associate my living room lamps with a wall switch, but those seem to be discontinued or out of stock EVERYWHERE. Aeotec, Hank/monoprice, Inovelli, any others I missed. I would consider zigbee and/or Hue but I would want to use a USB zigbee stick for direct control but again the Conbee ii is out of stock. And then there is wifi :cry: what are our options there that don’t involve the cloud? I really do not want to go the wifi route.
I just got 4 of the Sylvania Zigbee RGB bulbs from Amazon and they seem to be working out quite well.
I know you were asking about Zwave, but if that doesn’t work out for you, maybe these will.
Are you using a separate zigbee hub or a zigbee stick?
I use the Nortec Zigbee/Zwave stick.
Conbee is not the only player.
This guy might help you out Conbee II not available on Amazon - #3 by tube0013
1.Philips Hue White And Color Ambiance. The best smart light bulb starter kit.
2.Wyze Bulb iMessage
3.Sengled Smart LED with Motion Sensor.
4.Sengled Smart Wi-Fi LED.
5.Ring Solar Pathlight.
How does the zwave work on that? I have the aeotec z stick currently.
I went with this stick as a ā€œjust in caseā€, but have only ever used the Zigbee side of it.
