Best selfmade hardware/settings for Homeassistant Assist Microphone ?!
I would like to build a self-made home assistant microphone, I have already done a bit of tinkering and ended up with the following hardware.
ESP32 MIni [with ESPhome Code]
INMP441 microphone
MAX98357A Audio Amplifier
3-watt speakers (for output)
Software:
faster-whisper with CUDA (on GPU, takes 0.96 sec for a command)
The whole thing actually works quite well, but on the one hand I always have crackling and crackling in the loudspeaker until I give the first command, then it stops, but the output, i.e. the response from the Assist, is constantly interrupted by disturbances.
But the main problem is that the microphone simply misunderstands me, regardless of whether I move closer or further away.
I then tested the whole thing and simply used my cell phone and whisper assist, and the assist understands me perfectly!
So it probably depends on the microphone I chose.
Here is my schematic
Here is my ESPHome sketch
captive_portal:
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO26   #WS / LRC
    i2s_bclk_pin: GPIO25    #SCK /BCLK
microphone:
  - platform: i2s_audio
    adc_type: external
    pdm: false
    channel: right
    bits_per_sample: 32bit
    i2s_audio_id: i2s_in
    i2s_din_pin: GPIO33    #SD
speaker:
    dac_type: external
    i2s_dout_pin: GPIO22   #DIN
    mode: mono
voice_assistant:
  microphone: mic_i2s
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 4.0
  use_wake_word: false
  speaker: my_speaker
  on_error:
   - if:
        condition:
          switch.is_on: use_wake_word
        then:
          - switch.turn_off: use_wake_word
          - switch.turn_on: use_wake_word
  on_client_connected:
    - if:
        condition:
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
binary_sensor:
  - platform: status
    name: API Connection
    filters:
      - delayed_on: 1s
    on_press:
      - if:
          condition:
          then:
    on_release:
      - if:
          condition:
          then:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
Does anyone have an idea of what hardware to use?
But I don’t want a ready-made solution, I would like to make it myself because I have already drawn a housing and would print it with the 3D printer.
I moved your post to voice category because I believe you can get help from someone with microphone/speaker settings in espHome.
I know if you look at the canned share your projects devices, there are a lot of microphone and speaker settings that could smooth things out for you.
I’m not an expert, but I thought you would have more focused eyes on your problem here.
(Feel free to move it back to hardware if you really think it needs to be there)
you can save spoken phrases and evaluate their quality
All the popular solutions that you can find work about the same way at the moment. The sensitivity of the microphone (or microphone array) is lower than that of smart speakers from large companies.
But at a distance of up to 3 meters, there should be no noticeable problems
move the i2s pins to different pins than 25 & 26 this has been known to cure the 'crackling issue" pins 25 & 26 are the internal DAC pins of the ESP32 so better to avoid using these
Here is my wiring for the same hardware.
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO25
    i2s_bclk_pin: GPIO26
  - id: i2s_out
    i2s_lrclk_pin: GPIO32
    i2s_bclk_pin: GPIO13
microphone:
  platform: i2s_audio
  adc_type: external
  i2s_din_pin: GPIO34
  pdm: false
speaker:
  platform: i2s_audio
  dac_type: external
  i2s_audio_id: i2s_out
  i2s_dout_pin: GPIO33
I have 4 of these that work pretty flawlessly. 2 with generic ESP32 boards and 2 with S-3 boards.
@robgough1970
i tried it first it works well, but then the crackling comes back when HA gives a answer… and now the esp cracklings and hangs, i must power off the device and reboot.
@Rich37804
what is on your connected?
  • id: i2s_out
can you show your esphome code complete?
and a electric schematic?
and you have the ESP32 WROOM32 ?
this is my Esphome device, is it wrong?
esp32:
board: esp32dev
framework:
type: arduino
no one ?
i need here help
ESP32 (WROOM-32) MAX98357A (Speaker) I2S Microphone
GPIO33 DIN -
GPIO12 LRCLK -
GPIO13 BCLK -
GPIO34 - SD
GPIO25 - WS
GPIO26 - SCK
3.3V VDD VDD
GND GND GND
substitutions:
  voice_assist_idle_phase_id: '1'
  voice_assist_listening_phase_id: '2'
  voice_assist_thinking_phase_id: '3'
  voice_assist_replying_phase_id: '4'
  voice_assist_not_ready_phase_id: '10'
  voice_assist_error_phase_id: '11'
  voice_assist_muted_phase_id: '12'
esphome:
  friendly_name: Living Room Voice Assistant
  on_boot:
    priority: 600
    then:
      - script.execute: control_led
      - delay: 30s
      - if:
          condition:
            lambda: return id(init_in_progress);
          then:
            - lambda: id(init_in_progress) = false;
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "snip"
ota:
  password: "snip"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "snip"
    password: "snip"
esp_adf:
external_components:
  - source: github://pr#5230
    components:
    - esp_adf
    refresh: 0s
captive_portal:
light:
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO18
    num_leds: 3
    rmt_channel: 0
    chipset: WS2812
    default_transition_length: 0s
    effects:
      - pulse:
          transition_length: 800ms
          update_interval: 800ms
          min_brightness: 0%
          max_brightness: 30%
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
i2s_audio:
  - id: i2s_in
  - id: i2s_out
microphone:
  platform: i2s_audio
  adc_type: external
  i2s_din_pin: GPIO34
  pdm: false
speaker:
  platform: i2s_audio
  dac_type: external
  i2s_dout_pin: GPIO12
  mode: mono
voice_assistant:
  microphone: external_microphone
  speaker: external_speaker
  use_wake_word: true
  auto_gain: 31dBFS
  volume_multiplier: 2.5
  on_listening:
    - lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
  on_stt_vad_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
  on_tts_stream_start:
    - lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
  on_tts_stream_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
  on_error:
    - if:
        condition:
          lambda: return !id(init_in_progress);
        then:
          - lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
          - delay: 1s
          - if:
              condition:
              then:
              else:
                - lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
    - if:
        condition:
        then:
        else:
    - lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
switch:
    name: Use Wake Word
    optimistic: true
    on_turn_on:
      - if:
          condition:
          then:
            - if:
                condition:
                    not:
                then:
    on_turn_off:
      - if:
          condition:
          then:
globals:
  - id: init_in_progress
    type: bool
    restore_value: no
    initial_value: 'true'
  - id: voice_assistant_phase
    type: int
    restore_value: no
    initial_value: ${voice_assist_not_ready_phase_id}
script:
  - id: control_led
    then:
      - if:
          condition:
          then:
            - if:
                condition:
                    wifi.connected:
                then:
                  - if:
                      condition:
                          api.connected:
                      then:
                        - lambda: |
                            switch(id(voice_assistant_phase)) {
                              case ${voice_assist_listening_phase_id}:
                                id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("none").perform();
                                break;
                              case ${voice_assist_thinking_phase_id}:
                                id(led).turn_on().set_rgb(0, 1, 0).set_effect("slow_pulse").perform();
                                break;
                              case ${voice_assist_replying_phase_id}:
                                id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("fast_pulse").perform();
                                break;
                              case ${voice_assist_error_phase_id}:
                                id(led).turn_on().set_rgb(1, 1, 1).set_brightness(.5).set_effect("none").perform();
                                break;
                              case ${voice_assist_muted_phase_id}:
                                id(led).turn_off().perform();
                                break;
                              case ${voice_assist_not_ready_phase_id}:
                                id(led).turn_on().perform();
                                break;
                              default:
                                id(led).turn_on().set_rgb(1, 0, 0).set_brightness(0.2).set_effect("none").perform();
                                break;
                      else:
                        - light.turn_off:
                else:
                  - light.turn_off:
          else:
            - light.turn_on:
                blue: 50%
                red: 50%
                green: 50%
                effect: "fast_pulse"
now mi use the same code and the same wiring as you. i have no crashes more, but i have no voice in the speaker now i have only crackling no undertandable speaking anymore.as answer.
have you by your setup the GND to L/R from the INMP441?
or must this i2s_lrclk_pin: GPIO32 be GPIO33 ?
there is no wiring for GPIO32
Yes, grnd to the L/R also. I dont see an issue with using GPIO 33
Make sure you have a good ground and 5V supply to the amplifier.
okay i will test to give L/R Grnd.
No i mean in your wiring table above there is no GPIO32 connected to something but in the ESPHome COde its deifnied.
is this correct?
EDIT
L/R to GND Changed nothing on the Problem witth the Speaker output.
I tried different configs on a couple devices. Both worked.
No, maybe I’m expressing myself wrong, you posted the connection diagram above. BUT the GPIO32 does NOT appear there.
but in your ESPHOME code the Gpio 32 is defined at “speaker” or under i2s_out
  • id: i2s_out
That’s what I mean, is that correct?
I have now changed again from 3.3V to 5V for the amplifier, but it still cracks, unfortunately I don’t get any sound in response from the voice assistant, just a cracking sound.
You can use 32, or 33. Either will work.
Some boards GPIO 12 is not a good choice for i2s_dout_pin, move that to another pin. Maybe 32, or 33. Whichever one you have open.
now it works well.
here for another user the right wiring
wiiring
do you have any guide/proven way to run faster-whisper on GPU?
it depends on the system you use, but its neccessary to use a Nvidia Card + Docker.
i buyed a GTX1680 OC 4GB for 80€ and put it in my Media Server with OMV6 where my Whisper run.
This Guide is for Ubunutu.
when you want to use it on omv6 wrote me a PM
gives a specific reason you use the “esp-idf” ?
i tried to add the media_player component, but this is not supported under the “esp-idf” Framework only under “adruino”.
