Alright, so I have a wife-proofing problem. After my zigbee2mqtt blew up after a restore failure (freaking routers won’t connect to the coordinator anymore), and I’m left with having to do a full re-pairing across the board, our main lights are now completely dead because they depend on HA and Zigbee2mqtt.
Are there any good options for a smart dimmer that can also talk directly to smart lights? or do I need to get rid of the smart lights? ugh.
Devices that can be fully owned (no only the hardware) can be extended with such functionalities, for example with esphome based devices you can check for a active HA api connection and in case it’s not present toggle a remote esphome node simply via a http request.
It would be even possible to add another condition and check if wifi is connected and in case it isn’t send maybe send the command via esp-now (direct device communication) with the help of a external component.
I wanted to do that in the first place, but couldn’t find anything working like this, so went with http_request at first but since that was somehow slow (and not reliable), went with calling HA service directly from device. Thanks for sharing this custom lib, I’ll have a look.
Smart light plus smart switch is usually bad juju and I simply avoid it. But since you’re in the US (assumed since you use lutron gear) and are already there.
Check out Inovelli Blue series. If you can find one they are what you are looking for. They pass power through to the end fixture in smart bulb mode and can direct bind via zigbee.
Correct - you could lookup zigbee binding. What is your smart bulb(s)?
The Lutron Aurora Dimmer does support direct control (aka Touchlink) to smart bulbs, if this specific smart bulbs also being zigbee, and support Touchlink.
So, as a reference point, I have used aurora dimmers on both IKEA Tradfri & Philips Hue bulbs. And they would dim just fine, from the dimmer switch, even when your zigbee coordinator is offline.
With both the bulb and the dimmer in the same zigbee mesh, and with the zigbee binding (between bulb and dimmer) in place,
(a) not sure what you meant by “in sync”, but anyways the dimmer switch can turn on / dim / turn off the smart bulb.
(b) Yes HA can control the bulb, as long as the bulb is part of the zigbee mesh where HA could control
(c) even when my HA being offline, the dimmer switch would still be able to control the bulbs - same turn on / off / dim behavior.
