Hello All,
So here is the scenario:
Walkthrough Closet with switches on both sides (TP Link Kasa 3 way switch installed)
Aqara motion sensor (arriving today - will be using tasmota)
Govee led wifi lights in the ceiling
What do you use when you don’t want anyone to be able to turn the power to the ceiling lights OFF?
Originally I was thinking I needed the 3 way switch to make sure the power stays ON but that doesn’t really make any sense.
Options:
Hard wire it behind the switch and then basically disable the switch but that just doesn’t seem like the right thing to do.
Change the TP Link Kasa settings to always flip the lights back on if someone turns them off - seems like a waste of money.
Tape up a sign that says, don’t turn off!!
I have a feeling you all will have a better solution than those 3 above!
Thanks in advance!
