Best USB Zwave and Zigbee adapters
With the new Smartthings PAT rules, I am considering moving all my devices from SmartThings to HA. I run HA on a NUC so I’m looking for recommendations from the community on USB Zwave and Zigbee adapters. I don’t know where to start? Will any work?
I was totally happy with SmartThings- Webcore until they broke it. Then I was happy for years with smartthings -HA marriage until now where I have to auth the PAT every 24 hours.
When I searched the forum this was all I found and it went unanswered: What are The Best USB Dongles To Use With Home Assistant Green ? For Zigbee, Zwave , Bluetooth, WiFi, etc?
I use a Zooz 800 Z-Wave controller. It is USB.
But for Zigbee I use a SMLIGHT SLZB-06 Zigbee Ethernet PoE USB WiFi Adapter. I am using it as an Ethernet POE adapter. No idea how it works with the other setups.
Both are working flawlessly. I run HAOS and have used it on both ESXi and Proxmox (current setup).
Thank you, I’ll try those
Just bought the same Zooz 800 Series as originally had purchased the Aeotec Smart Hub thinking I could get away with an all-in-one, only to find out that the integration is currently broken. Should be here in a couple days.
Question on the SMLight for zigbee stuff. I don’t have anything zigbee yet so still doing some research and see that the ones with the CC2652 chip are the most highly recommended (at least of POE). However I see that there are a few different versions, is there any major differences between them that one should be concerned about?
e.g. SLZB-06p7 vs. SLZB-06 vs. SLZB-06M (think this one is a different chip) vs. SLZB-06NoPOE (needs external power source outside of POE?)
I bought the SLZB-06 before the 06M or 06P7 were introduced.
Have had ZERO issues. Not much else I can say.
I’ve been using the “CONBEE II” for a couple of years now. Initially it was plugged into the back of a PI with HA on an SD card. I updated my HA to an external drive, tethered with a USB cable with the CONBEE next to it plugged directly into the back of the PI. This caused interference and signal drop out with Zig-Bee devices. Specifically my Zig-Bee wall plugs. These are about 25-30ft from my back studio in the house to where they are plugged into the front room of my house. Once I tethered the CONBEE and moved it away from the pi and external hard drive the interference disappeared. Now the CONBEE hangs off the back of my desk unseen on a USB cable (Make sure it’s one that does Data). I have about 20+ devices running off of it, from TRADFRI (IKEA) light bulbs to a handful of cheap Zig-Bee wall plugs. They all perform great. Some of the lights are as far as upstairs in a bathroom as well as in my living room where my TV is. They all respond very fast and seamlessly into HA using the Zig-Bee Home Automation (ZHA) application. So, it works well, disappears behind my desk so I don’t see it, and it reacts very fast with my devices. Out of sight, out of mind. Let us know on what you decide. Hope that helps.
