Hello all,
I am trying to create an automation that will turn on some of my lighting at 20% and over a 15 min period it will end at 80%.
I have found 2 ways that should work, but I can’t get them to work.
Home assistant looks like have this built in. Through the call service. This is what I did:
service: light.turn_on
brightness: 80
transition: 300
brightness_pct: 10
entity_id: light.dimmer_soveromlys
This did not work. Also, the slider only goes to 300 seconds, so I guess that is maximum, so not possible to reach the 15 minutes I am trying to reach…
The second way is through the adaptive lighting addon that I have installed.
I have added the bedroom light to the addon (in integrations) and I have changed the settings. The settings I have changed is: Transition time, min_brightness and max_brightness.
And after doing that I thought all I had to do was to call it from an automation? But I have not found a way under action to run it… All I have to choose from there under call service is: adaptive lighting apply and adaptive lighting set manual control… Both of them are wrong?
This is the closest I get for it to “look correct”:
service: adaptive_lighting.apply
entity_id: switch.adaptive_lighting_light_morningroutine
But if I run this nothing happens…
Any tips either with this, or other ways to gradually adjust light brightness over a given period of time?
