Hi all, I am trying to automate light in my house. The main goal is to synchronize smart switches and bulbs (either smart or dumb). For example, an usual room has:
- Zigbee wall switch on entrance (dumb ceiling lamp connected)
- Zigbee wall switch on the bed headboard (no wired devices)
- Smart light on the bed’s table
- IKEA remote
If, for example, wall switch (1) is pressed and wired ceiling light is switched on: wall switch (2) should be turned “on” so its led will lit; smart light (3) should be turned on.
Remote (4) button pressed: wall switches (1) and (2) is toggled, expecting that they are in sync; smart light (3) is toggled or switched on or off according to switch (1)
Smart light (3) is turned on by some other automation: switches (1) and (2) should be turned on to match the state of smart light
Currently if I try to make simple automations like: “if switch (1) is on OR switch (2) is on OR smart light (3) is on THEN turn on switch (1); turn on switch (2); turn on smart light (3)” - it works but gives a lot of warnings in the log like this:
Logger: homeassistant.components.automation.auto_bedroom_switches_on
Source: helpers/script.py:1341
Integration: Automation ([documentation](https://www.home-assistant.io/integrations/automation), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+automation%22))
First occurred: 10:18:42 AM (1 occurrences)
Last logged: 10:18:42 AM
Bedroom: Light Switches Group On: Already running
I am pretty sure it should be a better solution that checks state of each device before turning it on or off, or maybe even keep such group of devices “in sync” without separate automations?
