So I have a few ideas of how to accomplish this in my head, but I thought I’d ask the community to see how others would do it.
I have some permanent outdoor lighting set up, across two wLED controllers, on the front of my house.
How would you accomplish the following? —
If its between December 1st and December 31st, then play “christmas scene”
If its between February 8th and February 14th, then play “Valentines scene”
X) If its not any of the above dates, then just turn on dim white landscape lighting
(Obviously, I would only be turning this on at night time)
You could also create a local calendar with appointments naming the preferred scene, if nothing there use default lighting. That way you can schedule whatever scene you want, whenever you want. Birthdays, etc…
