Best way to check signal strength at nodes in zwave?
How to do it? , Thanks.
Goal is to know where to put zwave power plugs (that act as repeater)
I am looking for the same functionality.
Some code so you can get the signal strength for the nodes, when the node wakes up.
And some code that could send a notification/alert, if a node, did not report to Hassio when expected. This way alerting if battery is flat or signal is lost.
(RPI3/Z-Wave Aeon Labs Z-Stick Gen5/Hassio 0.60.1)
I am also looking for a way to see how good or bad the signal is for different devices.
For my Fibaro Roller Shutter 2 I see “sentCnt 31”, “sentFailed 6” - I have a lot of problems with it, only occasionally reacting and never sending back the proper states. The Raspi3 with hassio and the z-wave.me UZB stick is only 1 wall and one ceiling/floor away, maybe 3 meters distance.
Any help in debugging this would be appreciated!
