Best way to code input boolean selection
I am setting up a Alarm Clock automation and need suggestions on best way to use input_boolean selection to fire if daily state is equal to on.
Here is input_boolean in my configuration.yaml file
input_boolean:
monday:
initial: on
tuesday:
initial: on
wednesday:
initial: on
thursday:
initial: on
friday:
initial: on
saturday:
initial: off
sunday:
initial: off
Here is the automation I currently use which has the dates listed and I just comment out the days for the alarm to not fire.
#----Wake Up Alarm for Work Days
- id: alarm clock
  alias: "Alarm Clock Work Days"
#  hide_entity: true
  condition:
    - condition: time
      weekday:
#        - mon
        - tue
#        - wed
        - thu
        - fri
#        - sat
#        - sun
    platform: time
    at: '8:00:00' #Changed from after to at per log
    - service: media_player.media_play
        entity_id: media_player.runeaudio_mpd
    - service: light.turn_on
      entity_id:
        - light.cree_connected_a19_60w_equivalent_fe06c273_10
        - light.sengled_e11g13_0306678e_1
        - light.sengled_e11g13_03092691_1
        - light.sengled_e11g13_03092ed4_1
My schedule changes alot and need a way to just turn on or off each day
What I need is a way to have a condition check each day if input_boolean is on or not then if on run alarm.
Thanks for any help
- id: alarm clock
  condition:
    condition : or
      conditions:
        -  condition : template
           value_template: '{{ (now().strftime("%a") == 'Mon') and (states.input_boolean.1_Monday.state == 'on')}}
           value_template: '{{ (now().strftime("%a") == 'Tue') and (states.input_boolean.2_Tuesday.state == 'on')}}
    platform: time
      entity_id:
Some notes:
  1. I think itā€™s unlikely that input_booleans that have names that start with number will actually work.
  2. I havenā€™t actually run this code, so there may be formatting errors, but it should give you the JIST of what you are trying to do.
That is what I was looking for
Just need to get it working now
I added conditions for all days Mon-Sun
But when I reload automations I get the following error in the log
2017-09-09 21:51:38 ERROR (SyncWorker_0) [homeassistant.util.yaml] mapping values are not allowed here in "/config/automations.yaml", line 63, column 17 2017-09-09 21:51:38 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: mapping values are not allowed here in "/config/automations.yaml", line 63, column 17
Any ideas
Post your code and iā€™ll take a look.
condition:
condition : or
conditions:
value_template: '{{ (now().strftime("%a") == ā€˜Monā€™) and states.input_b$
value_template: '{{ (now().strftime("%a") == ā€˜Tueā€™) and (states.input_b$
value_template: '{{ (now().strftime("%a") == ā€˜Wedā€™) and (states.input_b$
value_template: '{{ (now().strftime("%a") == ā€˜Thuā€™) and (states.input_b$
value_template: '{{ (now().strftime("%a") == ā€˜Friā€™) and (states.input_b$
value_template: '{{ (now().strftime("%a") == ā€˜Satā€™) and (states.input_b$
value_template: '{{ (now().strftime("%a") == ā€˜Sunā€™) and (states.input_b$
platform: time
at: ā€˜08:00:00ā€™ #Changed from after to at per log
- service: media_player.media_play #turn_on
entity_id:
Youā€™ve got past errors. See where all those $ end the stings. Also, if you would please use the </> tool when posting code it would keep your formatting and give me a place to start from.
I was able to work out most of what you were trying to say.
You will have to replace the names of the input_booleans below with the names of your input_booleans.
This is valid yaml:
- alias: test
    platform: time
    at: '08:00:00' #Changed from after to at per log
  condition:
    condition: or
    conditions:
        value_template: '{{ (now().strftime("%a") == "Mon") and (states.input_mon.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Tue") and (states.input_tue.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Wed") and (states.input_wed.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Thu") and (states.input_thu.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Fri") and (states.input_fri.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Sat") and (states.input_sat.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Sun") and (states.input_sun.state=="on")}}'
      entity_id:
I still can not get this to work.
Reduced it down to just one line for the current day to troubleshoot it and its still not working.
  condition:
    condition: template
      value_template: '{{ (now().strftime("%a") == "Mon") and states.input_boolean.monday.state=="on")}}'
Copied it from the code you provided.
Thanksā€¦
Yea, but itā€™s not.
You are missing the opening paren before the phrase states.input_boolean.monday
Got it working.
Thanks for the help
Here is the code to help anyone else trying this.
The nameā€™s have 1_ etc before them to keep them sorted correctly
In configuration.yaml
input_boolean:
  monday:
    initial: on
  tuesday:
    initial: on
  wednesday:
    initial: on
  thursday:
    initial: on
  friday:
    initial: on
  saturday:
    initial: off
  sunday:
    initial: off
This is the Automation
- id: Alarm Clock
#  hide_entity: true
  condition:
    condition: or
    conditions:
      - condition: template
        value_template: '{{ (now().strftime("%a") == "Mon") and (states.input_boolean.monday.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Tue") and (states.input_boolean.tuesday.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Wed") and (states.input_boolean.wednesday.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Thu") and (states.input_boolean.thursday.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Fri") and (states.input_boolean.friday.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Sat") and (states.input_boolean.saturday.state=="on")}}'
        value_template: '{{ (now().strftime("%a") == "Sun") and (states.input_boolean.sunday.state=="on")}}'
trrigger:
    platform: time
      entity_id:
Now that I have this working of course I want to make it better.
Created a input_select to pick the wake up time.
But not sure how to use that variable in my automation
Here is the input_select
input_select:
  alarmtime:
    icon: mdi:alarm
    initial: "08:00:00"
    options:
      - "07:00:00"
      - "07:30:00"
      - "08:00:00"
      - "08:30:00"
      - "09:00:00"
      - "09:30:00"
      - "10:00:00"
And my automation.
Just canā€™t figure out how to use the variable from input_select
instead of hard coded time.
Here is the trigger and action I am using now
    platform: time
      entity_id:
change your trigger to run every 5 minutes.
Then add to your template yet another condition where the current time matches your input time.
There are LOTS of examples of Home Assistant alarm clocks
Hereā€™s one that eventually gets to what you want:
I have looked at all of the other examples of alarm clocks and it just looks to me like they handle it in a overly complicated way.
Maybe that is required.
Do you know of a way to just use the input_select variable alarmtime
to replace the ā€œ08:00:00ā€ I have hard coded.
Thanksā€¦
