I’m looking for a way to delay the re-execution of an automation. Any suggestions? UI or YAML ok. Thanks.
If it is a set amount of time, is you know how long you want to delay it, then make the automation mode single, then at the end of the automation, add a delay in actions, the last action.
This will result on the automation only run once at a time, and when it completes your desired action, the last action will be to delay the fix amount of time you want to wait before it is triggered again.
There are also other modes than just single.
Thank you!
