Hi all,
I don’t know if this is the proper place for this infomation, but I am also trying to get the HS-WD100+ switches to work. I was able to get the basic on off working with the xml files in the github pull request, but still want to get scenes working. I am new to both home-assistant and z-wave so I don’t know the code base very well. Below are the OpenZWave Control Panel logs for single click, double click, and triple click of the HS-WD100+ with the pull request applied. It shows up as Node003 in my control panel. To summarize the the logs below, I see this behavior on various clicks
All messages are Central Scene Set messages
Click Count |
SceneID |
Time |
1 up ---------- |
1----------- |
0 sec |
2 up ---------- |
1 ---------- |
3 sec |
3 up ---------- |
1----------- |
4 sec |
1 down ------- |
2----------- |
0 sec |
2 down ------- |
2----------- |
3 sec |
3 down ------- |
2----------- |
4 sec |
Single Click (up)
2016-12-26 12:42:36.198 Detail, Node003, Received: 0x01, 0x19, 0x00, 0x49, 0x84, 0x03, 0x13, 0x04, 0x11, 0x01, 0x5e, 0x86, 0x72, 0x5a, 0x85, 0x59, 0x73, 0x26, 0x27, 0x70, 0x2c, 0x2b, 0x5b, 0x7a, 0xef, 0x5b, 0x93
2016-12-26 12:42:36.199 Detail,
2016-12-26 12:42:36.199 Info, Node003, UPDATE_STATE_NODE_INFO_RECEIVED from node 3
2016-12-26 12:42:36.199 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2016-12-26 12:42:36.199 Detail, Node003, QueryStage_Dynamic
2016-12-26 12:42:36.199 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x1f, 0xfa
2016-12-26 12:42:36.199 Info, Node003, CentralScene RequestState: 4
2016-12-26 12:42:36.199 Info, Node003, CentralScene: Not a StaticRequest
2016-12-26 12:42:36.199 Detail, Node003, Queuing (Query) Query Stage Complete (Dynamic)
2016-12-26 12:42:36.200 Detail,
2016-12-26 12:42:36.200 Info, Node003, Sending (Send) message (Callback ID=0x1f, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x1f, 0xfa
2016-12-26 12:42:36.215 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-26 12:42:36.215 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2016-12-26 12:42:36.219 Detail, Node003, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x03, 0x05, 0x5b, 0x03, 0xb9, 0x00, 0x01, 0x16
2016-12-26 12:42:36.219 Info, Node003, Response RTT 19 Average Response RTT 27
2016-12-26 12:42:36.219 Info, Node003, Received Central Scene set from node 3: scene id=1 in 0 seconds. Sending event notification.
2016-12-26 12:42:36.219 Warning, Node003, No ValueID created for Scene 1
2016-12-26 12:42:36.233 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x1f, 0x00, 0x00, 0x03, 0xf7
2016-12-26 12:42:36.233 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x1f received (expected 0x1f)
2016-12-26 12:42:36.233 Info, Node003, Request RTT 33 Average Request RTT 32
2016-12-26 12:42:36.233 Detail, Expected callbackId was received
2016-12-26 12:42:36.244 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x03, 0xd4
2016-12-26 12:42:36.244 Info, Node003, Response RTT 44 Average Response RTT 35
2016-12-26 12:42:36.245 Info, Node003, Received SwitchMultiLevel report: level=3
2016-12-26 12:42:36.245 Detail, Node003, Refreshed Value: old value=0, new value=3, type=byte
2016-12-26 12:42:36.245 Detail, Node003, Changes to this value are not verified
2016-12-26 12:42:36.245 Detail, Node003, Expected reply and command class was received
2016-12-26 12:42:36.245 Detail, Node003, Message transaction complete
2016-12-26 12:42:36.245 Detail, Node003, Removing current message
2016-12-26 12:42:36.245 Detail, Node003, Notification: ValueChanged
2016-12-26 12:42:36.245 Info, Notification: Value Changed Home 0xf7caab7e Node 3 Genre user Class SWITCH MULTILEVEL Instance 1 Index 0 Type byte
2016-12-26 12:42:36.245 Detail, Node003, Query Stage Complete (Dynamic)
2016-12-26 12:42:36.246 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2016-12-26 12:42:36.246 Detail, Node003, QueryStage_Configuration
2016-12-26 12:42:36.246 Detail, Node003, QueryStage_Complete
2016-12-26 12:42:36.246 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2016-12-26 12:42:36.246 Detail, Node003, Notification: NodeQueriesComplete
2016-12-26 12:42:36.246 Info, Notification: Node 3 Queries Complete
2016-12-26 12:42:39.100 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x63, 0xb4
2016-12-26 12:42:39.100 Info, Node003, Received SwitchMultiLevel report: level=99
2016-12-26 12:42:39.100 Detail, Node003, Refreshed Value: old value=3, new value=99, type=byte
2016-12-26 12:42:39.101 Detail, Node003, Changes to this value are not verified
2016-12-26 12:42:39.101 Detail, Node003, Notification: ValueChanged
2016-12-26 12:42:39.101 Info, Notification: Value Changed Home 0xf7caab7e Node 3 Genre user Class SWITCH MULTILEVEL Instance 1 Index 0 Type byte
Single Click (down)
2016-12-26 12:42:58.665 Detail, Node003, Received: 0x01, 0x19, 0x00, 0x49, 0x84, 0x03, 0x13, 0x04, 0x11, 0x01, 0x5e, 0x86, 0x72, 0x5a, 0x85, 0x59, 0x73, 0x26, 0x27, 0x70, 0x2c, 0x2b, 0x5b, 0x7a, 0xef, 0x5b, 0x93
2016-12-26 12:42:58.665 Info, Node003, UPDATE_STATE_NODE_INFO_RECEIVED from node 3
2016-12-26 12:42:58.665 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2016-12-26 12:42:58.666 Detail, Node003, QueryStage_Dynamic
2016-12-26 12:42:58.666 Detail, Node003, Queuing (Send) SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x20, 0xc5
2016-12-26 12:42:58.666 Info, Node003, CentralScene RequestState: 4
2016-12-26 12:42:58.666 Info, Node003, CentralScene: Not a StaticRequest
2016-12-26 12:42:58.667 Detail, Node003, Queuing (Query) Query Stage Complete (Dynamic)
2016-12-26 12:42:58.667 Info, Node003, Sending (Send) message (Callback ID=0x20, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x20, 0xc5
2016-12-26 12:42:58.675 Detail, Unsolicited message received while waiting for ACK.
2016-12-26 12:42:58.676 Detail, Node003, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x03, 0x05, 0x5b, 0x03, 0xba, 0x00, 0x02, 0x16
2016-12-26 12:42:58.677 Info, Node003, Response RTT 8 Average Response RTT 21
2016-12-26 12:42:58.677 Info, Node003, Received Central Scene set from node 3: scene id=2 in 0 seconds. Sending event notification.
2016-12-26 12:42:58.677 Warning, Node003, No ValueID created for Scene 2
2016-12-26 12:42:58.678 Detail, Node003, CAN received…triggering resend
2016-12-26 12:42:58.678 Info, Node003, Sending (Send) message (Attempt 2, Callback ID=0x21, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=3): 0x01, 0x09, 0x00, 0x13, 0x03, 0x02, 0x26, 0x02, 0x25, 0x21, 0xc4
2016-12-26 12:42:58.687 Detail, Node003, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-12-26 12:42:58.687 Detail, Node003, ZW_SEND_DATA delivered to Z-Wave stack
2016-12-26 12:42:58.703 Detail, Node003, Received: 0x01, 0x07, 0x00, 0x13, 0x21, 0x00, 0x00, 0x02, 0xc8
2016-12-26 12:42:58.704 Detail, Node003, ZW_SEND_DATA Request with callback ID 0x21 received (expected 0x21)
2016-12-26 12:42:58.704 Info, Node003, Request RTT 25 Average Request RTT 28
2016-12-26 12:42:58.705 Detail, Expected callbackId was received
2016-12-26 12:42:58.715 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x61, 0xb6
2016-12-26 12:42:58.716 Info, Node003, Response RTT 36 Average Response RTT 28
2016-12-26 12:42:58.716 Info, Node003, Received SwitchMultiLevel report: level=97
2016-12-26 12:42:58.717 Detail, Node003, Refreshed Value: old value=99, new value=97, type=byte
2016-12-26 12:42:58.717 Detail, Node003, Changes to this value are not verified
2016-12-26 12:42:58.717 Detail, Node003, Expected reply and command class was received
2016-12-26 12:42:58.717 Detail, Node003, Message transaction complete
2016-12-26 12:42:58.718 Detail,
2016-12-26 12:42:58.718 Detail, Node003, Removing current message
2016-12-26 12:42:58.718 Detail, Node003, Notification: ValueChanged
2016-12-26 12:42:58.719 Info, Notification: Value Changed Home 0xf7caab7e Node 3 Genre user Class SWITCH MULTILEVEL Instance 1 Index 0 Type byte
2016-12-26 12:42:58.719 Detail, Node003, Query Stage Complete (Dynamic)
2016-12-26 12:42:58.719 Detail, Node003, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2016-12-26 12:42:58.720 Detail, Node003, QueryStage_Configuration
2016-12-26 12:42:58.720 Detail, Node003, QueryStage_Complete
2016-12-26 12:42:58.720 Warning, CheckCompletedNodeQueries m_allNodesQueried=1 m_awakeNodesQueried=1
2016-12-26 12:42:58.721 Detail, Node003, Notification: NodeQueriesComplete
2016-12-26 12:42:58.721 Info, Notification: Node 3 Queries Complete
2016-12-26 12:43:01.567 Detail, Node003, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x03, 0x03, 0x26, 0x03, 0x00, 0xd7
2016-12-26 12:43:01.568 Info, Node003, Received SwitchMultiLevel report: level=0
2016-12-26 12:43:01.568 Detail, Node003, Refreshed Value: old value=97, new value=0, type=byte
2016-12-26 12:43:01.568 Detail, Node003, Changes to this value are not verified
2016-12-26 12:43:01.569 Detail, Node003, Notification: ValueChanged
2016-12-26 12:43:01.569 Info, Notification: Value Changed Home 0xf7caab7e Node 3 Genre user Class SWITCH MULTILEVEL Instance 1 Index 0 Type byte
Double Click (up)
2016-12-26 12:41:03.990 Detail, Node003, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x03, 0x05, 0x5b, 0x03, 0xb5, 0x03, 0x01, 0x19
2016-12-26 12:41:03.990 Info, Node003, Received Central Scene set from node 3: scene id=1 in 3 seconds. Sending event notification.
2016-12-26 12:41:03.990 Warning, Node003, No ValueID created for Scene 1
Double Click (down)
2016-12-26 12:41:43.110 Detail, Node003, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x03, 0x05, 0x5b, 0x03, 0xb6, 0x03, 0x02, 0x19
2016-12-26 12:41:43.111 Info, Node003, Received Central Scene set from node 3: scene id=2 in 3 seconds. Sending event notification.
2016-12-26 12:41:43.111 Warning, Node003, No ValueID created for Scene 2
Triple Click (up)
2016-12-26 12:41:56.869 Detail, Node003, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x03, 0x05, 0x5b, 0x03, 0xb7, 0x04, 0x01, 0x1c
2016-12-26 12:41:56.869 Info, Node003, Received Central Scene set from node 3: scene id=1 in 4 seconds. Sending event notification.
2016-12-26 12:41:56.869 Warning, Node003, No ValueID created for Scene 1
Triple Click (down)
2016-12-26 12:42:18.503 Detail, Node003, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x03, 0x05, 0x5b, 0x03, 0xb8, 0x04, 0x02, 0x10
2016-12-26 12:42:18.504 Detail,
2016-12-26 12:42:18.504 Info, Node003, Received Central Scene set from node 3: scene id=2 in 4 seconds. Sending event notification.
2016-12-26 12:42:18.505 Warning, Node003, No ValueID created for Scene 2
