i’m trying to find a solution to avoid accidentally cover open when security alarm is armed (away or night).
One solution looks at create a template cover (and export them on GA\Alexa\HomeKit instead of real cover) and for the open action use a script that check the status of the alarm and avoid accidentally open.
Did you know if there is another “smart” solution?
are you able to “monitor” the cover states within HA also when triggerd by 3rd party Alexa,Google and Homekit?
If so have a automation monitor the states and if it changes even when “alarm ist still in armed mode” then let it close the cover in question again and let it inform you… on your desired media.
this would be one of many options but it really depends on what “covers” you are using.
Yes I’m using Shellies 2.5 in roller mode over MQTT. The problem is that I don’t want to open rollers when alarm is armed to avoid alarm trigger (I’ve sensor on each roller to avoid raise up)
Rather than exposing the cover to HomeKit you could expose a script that opens the cover. Include a condition in the script that the alarm must be off.
but i want to expose as a cover and not as a switch, and the problem is also related to GA\Alexa.
I’m trying to do a “Template Cover” using a script but i’ve a problem on the open part. I want to use just a single script and pass the entity_id based on the roller shutter, but it doesn’t work. Here is the configuration:
cover:
covers:
tapparella_test:
device_class: blind
friendly_name: "Tapparella Test Allarme"
value_template: "{{ states('cover.shelly2_5_bcddc277b83e_roller_0') }}"
position_template: "{{ state_attr("cover.shelly2_5_bcddc277b83e_roller_0", "current_position") }}"
open_cover:
service: script.open_cover
cover_name: cover.shelly2_5_bcddc277b83e_roller_0 <-- this should be passed to the script
close_cover:
service: cover.close_cover
entity_id: cover.shelly2_5_bcddc277b83e_roller_0
stop_cover:
service: cover.stop_cover
set_cover_position:
service: cover.set_cover_position
data
position: "{{ position }}"
i think it’s not working as intended…
the open\close now works executing the script, but the problem is that the condition is not honored and also if the alarm is not in “disarmed” state, the script still execute calls to open\close cover services.
ok… it looks like that state is matched only from Lovelace UI, but not from HA\GH or Alexa.
Is it normal?
EDIT: i’ve found that HA\GH\Alexa are using “set_cover_position” and not “open\close”, putting another script using the same approach make it working as expected
