Hey all! One of the things I constantly strive for in my setup is to have everything Just Work, even though my setup is, uh, slightly more complex than “WiFi bulb”.
The two main issues that bug me (which thankfully only happen occasionally) are when:
- A device needs to react once to a changing state and it does not respond the first try. E.g blink an LED when something starts, turn something on when you walk in.
I fixed this one using a reusable script which accepts a list of entities and then repeats the action every X seconds up to X repeats or until the state matches the desired state.
- A device needs to be on when X=true. For example, consider a light that needs to be on from 17:00-22:00. But at 17:00, HA is restarting, Zigbee socket:// is offline, or the device is busy, or a power outage, etc.
This is the one currently stumping me. Of course, I can write it all out in my periodic checks automation using if statements that loop in parallel, but that sounds like mild torture for me.
The ideal implementation IMO is a state editor which allows you to say something like when x=y, make foo=bar. Of course, it would be very, very nice to have this natively, but there are more pressing things in HA development.
So I wanted to ask all of you folks: has anyone found a good way to do this either natively or in a custom app? If not, I might try to use AI to develop my own app so I can program easily and actually see visually what is set up to happen, but I wanted to ask first.
Thanks in advance!
