I just recently switched from Hass.io to Hassbian. Most of everything worked right away once I copied over the config directory. Two main things that I am having to setup manually is appdaemon and configurator. I have appdaemon setup and working as well as set to autostart.
I currently have Configurator working, just need to have it autostart when Home Assistant reboots. Looking at the documentation, it has me edit:
[Unit]
Description=HASS-Configurator
After=network.target
[Service]
Type=simple
User=homeassistant
#Set the path to your configurator.py location
WorkingDirectory=/etc/homeassistant
ExecStart=/usr/bin/python3 /etc/homeassistant/configurator.py settings.conf
Restart=always
[Install]
WantedBy=multi-user.target
However, I have already done something similar with appdaemon. So that service already has that template in it for appdaemon. My question is, can I add the Configurator template below what I already have for appdaemon or will there be a conflict with the headers? Or is there a better way of going about this? I feel I’m overthinking it.
Dear gpbenton,
Same question as makani47.
I do not how to create a new file as per your suggestion. Can you tell me how?
Thank you in advance
Minh Chau
