I was already googling and searching the forums.
I’m looking for something to realize the following:
- I have 2 raspberry pis acting as voice assistants which also happen to have a webcam connected to them
- I would like to use these webcams as cams in homeassistant which is running on another pi
Requirements:
- limit traffic, the webcams should not use a lot of network bandwidth when streaming
- limit cpu usage and memory consumption, should not be too resource hungry
- should run in docker for easy deployment and update (I usually write docker-compose files to deploy on each pi)
The only thing I found is motioneye, but it seems a bit outdated and not well maintained. I am trying this now but would appreciate other recommendations.
