This can be done with the wonderful Lovelace: Button card.
For the back-end part:
- You need an input-select setup, you have apparently
- You need automations so that each time you change the “input-select”, the right scene is set or action executed.
For the front-end:
- Create a horizontal-stack that will contain your 4 buttons
- Add 4 blocks in it of type a custom:button-card
Here is my setup expanded.
You have to change the icon/label & action to execute when button is pressed.
This includes the “state logic” to adapt button back-color when the selection of the input-select matchs a given value associated with the button.
And the component allows a lot more…check the doc.
The “template” as proposed by Tom_I is a even a more cleaner way to avoid copy of 4 times the same layout.
- type: horizontal-stack
cards:
- type: custom:button-card
icon: mdi:seat
tap_action:
action: call-service
service: input_select.select_option
service_data:
entity_id: input_select.state_bureau
option: 'homeworking'
hold_action:
action: more-info
show_icon: true
show_name: true
entity: input_select.state_bureau
styles:
card:
- background-color: rgb(59,64,72)
state:
- value: "homeworking"
styles:
card:
- background-color: white
- color: rgb(59,64,72)
icon:
icon: mdi:weather-night
tap_action:
service_data:
option: 'day'
hold_action:
action: more-info
show_icon: true
show_name: true
styles:
card:
state:
- value: "day"
styles:
card:
icon:
icon: mdi:weather-sunny
tap_action:
service_data:
option: 'evening'
hold_action:
action: more-info
show_icon: true
show_name: true
styles:
card:
state:
- value: "evening"
styles:
card:
icon:
icon: mdi:power-plug-off
tap_action:
service_data:
option: 'sleep_all'
hold_action:
action: more-info
show_icon: true
show_name: true
styles:
card:
state:
- value: "sleep_all"
styles:
card:
icon:
