Lovelace: Button card
Button card
Lovelace Button card for your entities. -> github
all
Features
  • works with any toggleable entity
  • 3 actions on tap toggle, more_info and service
  • state display (optional)
  • custom color for on and off state (optional)
  • custom state definition with customizable color (optional)
  • custom size (optional)
  • custom icon (optional)
  • custom css style (optional)
  • automatic color for light (optional)
  • custom default color for lights (when color cannot be determined) (optional)
  • 2 color types
    • icon : apply color settings to the icon only
    • card : apply color settings to the card only
  • automatic font color if color_type is set to card
  • support unit of measurement
  • blank card and label card (for organization)
  • support for custom_updater
Options
Name Type Default Supported options Description
type string Required custom:button-card Type of the card
entity string Required switch.ac entity_id
icon string optional mdi:air-conditioner | attribute Icon to display in place of the state. If you use attribute it will fetch the icon configured on the entity.
color_type string icon icon | card | blank-card | label-card Color either the background of the card or the icon inside the card. Setting this to card enable automatic font and icon color. This allows the text/icon to be readable even if the background color is bright/dark. Additional color-type options blank-card and label-card can be used for organisation (see examples).
color string var(--primary-text-color) auto | rgb(28, 128, 199) Color of the icon/card when state is on. auto sets the color based on the color of a light.
color_off string var(--disabled-text-color) rgb(28, 128, 199) Color of the icon/card when state is off.
size string 40% 20px Size of the icon. Can be percentage or pixel
action string toggle toggle | more_info | service Define the type of action
service Object optional See example section Service to call and service data when action is set to service
name string optional Air conditioner Define an optional text to show below the icon
show_state boolean false true | false Show the state on the card. defaults to false if not set
style object optional - text-transform: none Define a list of css attribute and their value to apply to the card
state list optional See example section State to use for the color of the button. Multiple states can be defined
Instructions
  1. Download the button-card
  2. Place the file in your config/www folder
  3. Include the card code in your ui-lovelace-card.yaml
title: Home
resources:
  - url: /local/button-card.js
    type: module
  1. Write configuration for the card in your ui-lovelace.yaml
To configure custom_updater with button-card
custom_updater:
  card_urls:
    - https://raw.githubusercontent.com/kuuji/button-card/master/tracker.json
Examples
Show a button for the air conditioner (blue when on):
ac
- type: "custom:button-card"
  entity: switch.ac
  icon: mdi:air-conditioner
  color: rgb(28, 128, 199)
Show an ON/OFF button for the home_lights group:
no_icon
  entity: group.home_lights
  show_state: true
Light entity with custom icon and “more info” pop-in:6
sofa
  entity: light.living_room_lights
  icon: mdi:sofa
  color: auto
  action: more_info
Light card with text:
text
  icon: mdi:sofa
  color: auto
Light card with text and custom style:
home-custom
  entity: light._
  icon: mdi:home
  color: auto
  action: more_info
  style:
    - color: rgb(28, 128, 199)
    - font-weight: bold
Light card with card color type, name, and automatic color:
color
  entity: light._
  icon: mdi:home
  color: auto
  color_type: card
  default_color: rgb(255, 233, 155)
  action: more_info
  style:
    - font-size: 12px
    - font-weight: bold
Horizontal stack with :
  • 2x blank cards
  • 1x volume up button with service call
  • 1x volume down button with service call
  • 2x blank cards
volume
- type: horizontal-stack
  cards:
      color_type: blank-card
      color_type: card
      color: rgb(223, 255, 97)
      icon: mdi:volume-plus
      action: service
      service:
        domain: media_player
        action: volume_up
          entity_id: media_player.livimg_room_speaker
      color_type: card
      icon: mdi:volume-minus
      action: service
      service:
        action: volume_down
Credits
  • ciotlosm for the readme template and the awesome examples
Edit :
  • New release! 0.0.1 is out.
  • 0.0.2 is out with custom service, blank card, and custom_updater support
  • 0.0.3 Custom state, label card and icon attribute
Lovelace as a Dashboard
Lovelace with custom_ui tiles
Lovelace button card (capital letters and blank cards)
Custom UI: Tiles
Lovelace: mini graph card
Lovelace light control ideas wanted
Ariela - Home Assistant Android Client
🟣 Rounded - Dashboard guide
My Lovelace Plugins
Tap to show more-info of a different entity
Ways of `mimicking` standard Lovelace elements in custom cards (like button-card), anyone?
Touchy - Touch friendly media player card (combination of cards)
Lovelace: alternative to multiple entity row?
Glance Card | Change Icon Color based on state
Palm Springs Theme
Custom Component - ESXi Stats
LIFX Smooth Color changing
Theme option for card background image?
Kodi Remote
Custom Lovelace Card - Homekit style card
Super Simple question....!
iOS 16 Home Theme
Clean Tile-Based Lovelace UI - only 2 cards needed!
Venetian Blind Icons
How to set select.select_option vaue from the select option
Hue scenes mimicked in Ha (and on Buttons, was Tiles)
Fun with custom:button-card
A different take on designing a Lovelace UI
Custom:button-card template
iTunes Switches for AirPlay or Playlists
How to create "Empty Row" or more spacing between 2 Buttons
Need help with picture Elements card CSS style
Color Custom Button Cards based on Attribute States
Media player in lovelace
🔹 Card-mod - Add css styles to any lovelace card
Button card that is blank?
Custom button card : action depending on state
[HELP] Display number of lights on
Lovelace: Simple thermostat card
Please help with my menu
Include template
Remove symbols to gain space
Idea: cards similar to those in Android 11 power menu
Tile vs custom:button-card: last-changed/seen/updated value on the card
Change icon color on Condition
How to template a simple button with a "confirmation" value
Homekit Infused 5 (HKI) *DEPRECATED - Check out HKI Elements instead
WTH can't I have a multiple position switch or helper
Split Entity State
iOS 16 Home Theme
Creative Button Card Templates for Lovelace Dashboards
How do I add a status to person icon?
Set background color to match RGB color
Custom Button Card Entity Attribute State
Navigation based on input select
Terminology for Noob with years of programming experience
Styling elements in Picture elements card: a small tutorial
Change icon entity on battery level
Trying to find specific button type
Please have a look: calendar title not changing button-card background
Custom Button Card - flash when condition is met
Button-card removes round styling?
Custom:Button-Card, that changes icon based on door sensor and border has animation with light on
Raw Configuration Editor - "value template" issue
UI Lovelace Battery Card not working
🔹 Layout-card - Take control of where your cards end up
Unable to get dashboard to show 12 hour
🧭 Navbar card: easily navigate through dashboards
Customized cards for data from the "FeelFit integration"
Showing 3-Way Switches in the GUI
Custom Button Card; change background based on other entity's state
Harmony Activities, Volume Slider, and Lovelace
Button background color based on value (range)
Best way to manage visually an input_select linked to scene in lovelace?
Icon change within custom button card
Klick, Jump, Link to tab from 1st tab
Icon size singel button card
Circadian Lighting [Custom Component]
Getting switch state in Entity Button Card
Color of active devices
Table like clickable PNGs to publish MQTT
How do I actually make a TV Remote Control work well in the GUI
Change entity color based on its state
How to make state_color: true global?
Custom UI: Tiles
Custom UI: Tiles
Change switch states from on/off in front end
Lovelace more then one Custom cards for one entity
Change icons on card and remove extra buttons
Custom UI: Tiles
Sonoff /eWeLink component for original firmware
How to change the displayed name of switch state
Is it possible to use PNG icon in Entity Button Card
this is awesome! great work
thank you, this looks amazing…
@kuuji Fantastic work! Any chance you can share the code for the layout you have in the first post? Really like the format / spacing setup :slight_smile:
Very nice! Just what I’ve been waiting for to jump on the Lovelace train :grinning:
If only we could pass data values like we used to in Custom UI: Cards :slight_smile:
  - entity: script.press_button
    icon: mdi:arrow-left-thick
    column: 1
    row: 5
      value: left
@kuuji (Alexandre) thank you for these great cards.
Please consider adding the below card tracker component code, as it’s a practical way of keeping up with your latest release.
Excellent start!!
Couple of things:
  1. Can the icon also use a regular image? Not all icons are available on mdi. For example, I would like to have buttons for my favorite TV channels (Discovery, CNN, etc.).
  2. Also, can we also allow calling services in action? We already have that feature in many LL cards, so should be easy to replicate the functionality here.
Thanks for the suggestion @arsaboo . Adding that to my todo list :wink:
@Igor_Jurisic not exactly sure what that does. Could you elaborate?
Thanks @juan11perez! That’s awesome. I’ll include the json and link to the tracker card/component in my readme :wink:
loving this card… but been trying to display on a raspberry pi with the 7" touchscreen, but keep getting “custom element doesn’t exist: button-card” could very well be me and nothing to do with the code, or it just isn’t compatible with the browser on the pi. working very well on other browsers. thanks again for all the work.
Just wondering how you put the text underneath each button “Main”, “Wardrobe” etc?
This is my configuration with name under icon’s:
        entity: switch.kino_on_off
        icon: mdi:power-standby
Ahhh “name:” was just thinking I hadn’t tried that…thanks mate!
@ashsav could you open the developer tools, go to the console, and tell me if you see any error.
It might just be slow to load on a raspberry Pi, have you tried waiting a bit?
Thanks for the reply, this is all I get
don’t think this is an error relating to my problem, but my web skills are limited. yeah I did try and wait, but no change.
I forked your project and I Improved it a little, if you like my edits you are free to add to your branch :slight_smile:
@jackar Feel free to open a PR. It’ll be easier for me to see what you change and to merge it into mine :wink:
Beautiful, great work.
Great job, was what I needed to stop using “custom-ui-tiles”.
But you still need a button with the name only (no icon and no state).
