Im sure there is already some integration that will read DC voltage from charge controller or directly from PV and get this into home assistant?
I already have whole house energy monitoring with solar clamp and works GREAT! but i would also like to get real data from panels and batteries… anything out there i can make or buy for this? Emporia Vue and SHelly EM cant read DC Voltage that i can see but there must be a DC clamp sensor that already is known working in home assistant for DC?
I use 1 of these https://www.snektek.com/forum/viewtopic.php?f=3&t=48
But it will all depend on what make/model of charge controller you are using
Nice bit of kit but feedback from the developer is a bit slow & hit + miss unforyunately
I have Renogy advanced rover Li 40 Amp Mppt charge controller I assume its compatible with the unit? Compatibility list is not very detailed… My controller has the bluetooth dongal connected currently via rs232 so it “should” work i think
@xion2000 i finally got the snektek device and its not working with my charge controller. I hope it is something i can fix as i was very excited to get it! Added entities easy enough into HA but of-coarse they all show no data but they are there just need the snektek to work with my model charge controller. I even asked Jonathon before purchasing if it would work with my model and he said yes so must be something i am missing in setup? Even though it seems very simple to setup. Fingers crossed
Tried changing to port 90 but still no data. I suspect the unit may not work with my model charge controller even though I was told yes it would work. Also I’m on firmware v4 not sure if it’s latest? Update channel is set to “stable” and shows no updates but was told when I purchased unit it was v5?
@xion2000 finally got snektek working but Jonathan had to change code for me as my id in Renogy controller was 255! With that change it worked. Anyways now with home assistant I added sensors and all works fine but randomly home assistant looses connection to random sensors like will show battaery voltage and todays generation but displays others as unavailable and then randomly they will re appear. I’m wondering if it’s not a power issue with snektek or is home assistant polling to often? How do you have yours setup in home assistant and do you see random unavailable?
If you have a read through my posts on the snektek forum, I had similar issues in HA and did eventually find a workaround, so you might find the solution in there
I’d like to point out that a mysolardashboard.com Cloud Subscription is not necessary to use Home Assistant, however there’s a REST API on the cloud as well that can be used conveniently connect to remote home assistant instances.
