Hello, I have a question about setting up website monitoring using HA and appdaemon.
First, I have used Nagios/Zabbix for years so I really just want something quick and dirty. Also, I work from home 99% and have access to HA all the time.
Basically I would like to group the sites into critical, medium and sobeit - respectively polling at 3, 15 and 30 minute intervals…with appropriate notifications. I would like to see the status of everything in Home Assistant. I’m not sure which cards to use, considering there may be 20-25 websites displayed.
Right now the calls to the websites (maybe 10 for now) are binary_sensors using curl and the command_line platform in HA. Needless to say, HA is taking longer and longer to reboot, so I would like to offload these http(s) calls to appdaemon. I also would like HA to trigger the 3,15,30 minute events so I can turn the automation off (with all the others in HA) in case something goes awry.
The last thing is I would like to keep ONE list of the URLs being called, so that has to be done in HA since that is where I am displaying their statuses. In other words, if I add/remove a site, I don’t want to have to update a list in both appdaemon and HA.
I thought about using the rest binary_sensor platform, and make the call in appdaemon using the “resource” attribute which contains the url. But can I ‘set’ the state of the binary sensor afterwards? Would this be a good approach? Is there an API call in appdaemon similar to curl?
I also thought of using an input_boolean but that leaves me with the burden of maintaining a separate list of urls, all of which I would have to pass in as parameters into appdaemon, somehow.
Is there another way of doing this?
Any insight would be appreciated.
