I’ve just got my air conditioner added to home assistant.
It’s a ducted unit, so it has only two fan speeds and no “vane” either. However the integration I’m using (Mitsubishi2MQTT) shows it as having 6+ fan speeds, vane settings etc.
What is the best way to restrict it so the unavailable settings are not shown? I had a look and unfortunately the integration itself appears to have no way to do this, are there any workarounds I can use?
If matters, I’m using the simple-thermostat card GitHub - nervetattoo/simple-thermostat: A different take on the thermostat card for Home Assistant ♨️
Thanks!
