Best way to sequentially switch relays?
Hi all. I’d like to check here with the community if I’m doing the best thing possible. Here’s what I want.
I want to switch inductive load. A standard electromechanical relay (EMR) alone does not work here since each switch there is a potential EMI causing the controller to reboot. So I’m doing a combination of SSR and EMR.
  • Turn on means turn on SSR to gently turn on the load, then after a short delay turn on EMR to shunt the SSR (so that nearly all the current goes through EMR).
  • Turn off means turn off EMR (so that all the current go again through SSR and turn off SSR after a short delay.
This is what I do (below). Is there any better way to achieve the same?
switch:
  - id: relay_1
    name: "Combined Relay #1"
    platform: template
    # These sections are required to correctly set states of the template relay
    turn_on_action:
      - switch.template.publish:
          state: ON
    turn_off_action:
          state: OFF
    on_turn_on:
      - logger.log: "Relay #1 turned ON"
      - switch.turn_on: ssr_1
      - delay: 500ms
      # Since there is a delay, then it's technically possible that the state of
      # this combined relay gets changed. So we are checking for the state again
      - if:
          condition:
            - switch.is_on: relay_1
          then:
            - switch.turn_on: emr_1
    on_turn_off:
      - logger.log: "Relay #1 turned OFF"
      - switch.turn_off: emr_1
      - delay: 500ms
      - if:
          condition:
            - switch.is_off: relay_1
          then:
            - switch.turn_off: ssr_1
  - platform: gpio
    name: 'SSR Ventilation'
    pin:
      number: GPIO32
      inverted: yes
  - platform: gpio
    name: 'Mechanical Relay Ventilation'
    pin:
      number: GPIO33
      inverted: yes
      mode: OUTPUT
