@tom_el_camino, did you manage to create an integration for home assistant. I was also looking for a good source of weather data, and found the KMI app. It uses an api (https://app.meteo.be).
By looking at the code of the app, I managed to figure out how it works. However, I’m not a coder … So I’m looking for someone who could help me in creating an home assistant integration based upon the KMI api.
Yeah, unfortunately I’m in the same boat. Didn’t manage to get it going.
Tried with webscraping, but the result the default weather forecast is actually so accurate close to kmi, I’m just using that one.
I managed to write a small python scripts that uses the meteo.be api to retrieve the forecast data, but I’m not skilled enough to create a home assistant integration based upon it.
@wernerkarlheisenberg@amedia I was looking into the possibility of integrating the KMI forecasts into HA and stumbled across this topic. It sounds like you both found a way to interact with meteo.be (through an actual api?) in a way that I haven’t managed to find at this time. The best I seem to be able to do would be to process and extract the relevant data from the response of e.g. https://app.meteo.be/nl/meteo/change-day/1/21004?
Is this what you did as well, or could give some guidance in a different direction?
