What is the best solution to buy?
I have zwave, zigbee and RFXcom installed. Power supply would be possible.
This is what I need:
- mean wind value
- gust speed value
- updates every minute or less
- ultrasonic preferred
I have one of these, love it. Connects with WIFI. Solar powered. There is a local MQTT based custom integration and a cloud based custom integration available.
Unfortunately this is not available in Europe.
Wittboy from ecowitt.
Can Share a Bit more later
as promised here is a bit info for my new Wittboy.
Its available globally and I looked really long for a PWS with so much capabilities.
There is direct Homeassistant Integration … and you have the data flowing in seconds
The set consists of an:
Outdoor sensor array with Wind, Temp, Rain, Humidity etc … Powered by a solarpanel and super condensator
a base station that can receive many many sensors
you can add lightning detections, leak sensors, additional indoor and outdoor temp and humidity sensor, soil moisture and many more
the integrated webserver from the base station can directly expose the data to HA in the LAN and additionally upload the data to a selection of cloud services (free and optionally)
Thats how it looks when I unboxed it:
That the integration in Home Assistant: (the screenshot still shows my windsensor from before I got the Wittboy)
Hi Sebastan,
Are you still happy with your weather station ?
Maybe I will buy it, so…
Thanks !
yes I think its really really good
I added also their sensors for more indoor temp and humidity, soil moisture, leak detection
all works like a charm and is functional with the official home assistant integration
Nice !
Did you buy it directly on the ecowitt website ? I live in Belgium (Europe).
I think I will start with this : ecowitt WittBoy new 7-in-1 weather station – Ecowitt
I probably don’t need a screen, I will use my kiosk tablet I already use for home assistant. But I could buy that eventual later, yes ?
And of course also a sensor for inside : WH31 – Ecowitt
Have I thought of everything?
Does the Wittboy require the gateway? I bought one on Amazon and it came without the gateway.
For Tinkerer:
