mrh
(Mark Holbrook)
November 28, 2019, 2:36pm
1
Hi all,
Fairly new to HomeAssistant but I’ve managed to get my ring doorbell and honeywell thermostats to work.
I have a bunch of Foscam PT cameras around the house and I see there is “some” support for them but I have get to get them working.
Can some one recommend good, inexpensive wired and WiFi cameras that I can use with HomeAssistant?
Thanks in advance!
tom_l
November 28, 2019, 2:43pm
2
All of these work with home assistant:
tom_l
November 28, 2019, 3:08pm
4
No worries. Thank the guy who did all the work.
finity
November 28, 2019, 7:52pm
5
What’s the problem with the Foscam camera’s? I have 6 of them (mostly wired but one is wifi) and they work fine.
mrh
(Mark Holbrook)
November 29, 2019, 2:26pm
6
Hi finity…
Well I have mostly the FI8910W and I have yet to get them to show a picture in HA.
If there is a hint you could give I’d much rather NOT replace them all.
One forum entry I found mentioned a custom component that worked but the poster did not mention where or what that custom component was.
Any hints would be most appreciated. I can get them to show up but they always show the broken image picture.
mrh
(Mark Holbrook)
November 29, 2019, 4:13pm
8
So after some more searching and playing I have my foscam cameras working.
I ended up using this code:
camera 3:
- platform: mjpeg
mjpeg_url: http://10.2.10.###:###/videostream.cgi?user=USER&pwd=PASS
This gives a nice image on the main display and clicking on the camera goes live. Thanks to other posters that posted how to do this.
In that same post a user contributed how to use motion with the following YAML:
- platform: command_line
command: 'curl -k --silent "http://10.2.10.###:####/get_status.cgi?user=USER&pwd=PASS" | grep alarm | cut -b 18'
value_template: >-
{%- if value == "0" -%}
Idle
{%- elif value == "1" -%}
Motion
{%- endif -%}
scan_interval: 5
But being a newbie at this I’m unsure where exactly to put this. Does it indent under the camera like:
camera 3:
- platform: mjpeg
mjpeg_url: http://10.2.10.###:####/videostream.cgi?user=USER&pwd=PASS
command: 'curl -k --silent "http://10.2.10.###:###/get_status.cgi?user=USER&pwd=PASS" | grep alarm | cut -b 18'
value_template: >-
Idle
Motion
{%- endif -%}
scan_interval: 5
Or is it its on thing?
finity
November 29, 2019, 4:20pm
9
Here is the config using the custom component for the Foscam SD camera’s:
camera:
- platform: foscamsd
ip: 192.168.1.51
port: 8001
username: !secret cam_user
password: !secret new_cam_pw
It’s also an FI8910W and works great,
Here is the link to the custom component:
Just to note that I believe that repo is no longer being maintained and the author recommends a different solution but I’ve been using that custom component for a long time and it still works fine.
That github file has some basic install instructions but there is one other thing you need that isn’t included. You need to create an empty __init__.py
file and place it in the same directory as the camera.py file in your custom component directory.
here is the resulting folder structure you should have (you don’t create the _pycache_
folder - the system creates that):
