Best Zigbee wallplugs that doesn't lose connection 24/7
I’ve used several zigbee wallplugs and even wifi ones. The wifi one is usually reliable and works all the time. However my Zigbees some times lose the connection and doesn’t work at all. I’m using Zigbee2Mqtt with the Sonoff E-dongle.
Can you list your best Zigbee wallplugs that has been working perfectly for you?
A hint as to which country you are in might be helpful :slight_smile:
Honestly, i only had problems with zigbee devices disconnecting only when i had the receiver too close to other devices emitting radios, once i moved the skyconnect away no disconnections at all.
I have a osram smart plug+, that works, but i found out these to be even better
https://it.aliexpress.com/item/1005005961001716.html?spm=a2g0o.order_list.order_list_main.11.53e036960aZ58Y&gatewayAdapt=glo2ita
I have one Aqara, two IKEA and four Hue, all works without losing connection.
You might want to check your zigbee channel and see if it interfers with wifi channels. Believe zigbee channel 25 is best/advised to use.
As some others here, I suspect this is due to the local quality of your Zigbee network at the location of the plug. So you’ve used ‘several’ zigbee plugs. Which ones? And did you use them at the same location or in different places. How many other routers are in your network and how far away are they from the plug?
I have six Tradfri plugs installed in the house, shed and office. They’ve been in for ages and I’ve never experienced loss of connectivity.
As others have advised, I’d try and determine why they are losing connectivity before blaming the plugs.
Thanks for all the replies.
I’m running zigbee on channel 11. And I had the dongle connected directly to the raspberry pi. So now I’ve got a usb extender for the dongle and moved it further away from all the wifi router/raspberry etc. So we’ll se if that made any improvement
If that doesn’t work I will try to change channel.
I’m using the wallplugs from aliexpress, different brands I believe. I will dig more into it when I get back home
I very much can confirm this.
Easy solution for me was to switch to wifi (esphome) devices and completely abandoned ZigBee. Since then everything works a treat without any hick ups at all.
No mention of location.
My zigbee Sengled and Third Reality US plugs have been 100% solid.
I threw away several Sonoff zigbee plugs.
I’m located in Scandinavia (Europe).
One of the plug that I have issues with is
Zigbee Model: TS011F
Zigbee Manufacture: _TZ3000_ew3ldmgx
Model: TS011F_plug_3
