Joe Farrow of Geektoolkit has posted a review of using the Bestjoy “Super Remote” with the optional MQTT Bridge in his Home Theater room. Filed this away under “Potential Harmony remote replacement”. There are a couple of other reviews on YouTube as well.
Check it out if you’re interested in an automation friendly remote and don’t mind the extra technical effort to setup.
I should have noted that this remote supports IR, IR learning, and Bluetooth. It has a database of devices for configuration similar to Harmony; as well as IOS and Android app support.
I can vouch for this remote. I’ve just set mine up and It is excellent.
It is a bit of a faff to setup, but super powerful.
I was very impressed with the IR range when used as a standard learning remote.
It is even better when used with the MQTT bridge, I think it uses Bluetooth in that mode.
I am controlling lights and launching Spotify playlists so far. Buttons can be assigned to trigger any HA script. That means many possibilities!
