I am currently taking my first steps using Home Assistant.
For the ZigBee-LED-strip, I integrated, Home Assistant chose the following interface automatically:
But the LED-strip does not support changing the white-temperature. All the temperature-slider does, is to change the brightness. Just as the brightness-slider above does as well.
Thus if I want to get the brightest setting, I need to move both sliders to opposite sides. And in order to get the lowest setting, I need to move both sliders to the other side.
Is there a better way to control the brightness?
Where can I start to read about the possibilities of the configuration?
Thank you!
