FPF92
(Fpf92)
1
Hello everyone,
I have found that controlling lamp groups is complicated if you want to switch all the lamps off or switch on the missing ones with the switch.
However, this is not a rare occurrence for me.
I could imagine dividing it into three scenarios:
all lamps are off:
In this case, you can simply switch on all the lamps
all lamps are on:
In this case, you can switch off all the lamps
parts of the group are on:
In this case, there are two options: all lamps in the group on or all lamps in the group off
Perhaps someone else has a better idea.
Thank you very much
tom_l
2
You can use scripts or scenes to do this.
FPF92
(Fpf92)
3
Thanks for the quick reply @tom_l!
Could you briefly explain how I can do this?
I thought the light card can not be customized with that.
The problem is if some lights are turned on I can not use the default switch to turn on the missing once.
Or did I got you wrong?
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
4
Hi ,
Like this: (there are 2 other automations in there from my latest video that might help you as well. https://whatarewefixing.today/1797/tuya-lights-in-home-assistant/)
FPF92
(Fpf92)
5
Thank you @Sir_Goodenough
I think this seems link a nice solution. Although I wanted to have it only in my dashboard and best way like a normal card not with hardware.
Do you know how to realize the card for that or customizing the default light entity?
Sir_Goodenough
6
I just have an entity card with the switch in it. I never care what the dashboard looks like, I usually voice everything.
frits1980
(Frits)
7
I think you can even do this with conditions and buttons on a dashboard.
FPF92
(Fpf92)
8
I will try and post it here. Thanks!
To change the more info screen Is not possible I guess.
