The current implementation of logs and history is archaic. It works if there is not that many entities connected, but quickly becomes unusable as entities grows.
I’ve almost completely given up on this, even having the logbook on local SD card is unusable.
Off loading of DB and logbook to USB disk - this will prevent the SD card dying quickly
Better usage of DB’s, it’s clear that it doesn’t utilize DB functions optimally if it’s running on an external MySQL / MariaDB, I’ve NEVER seen this slow response from a DB before.
Logbook to RAM, with the current support for larger memory systems such as RPi4 and others, there is sufficient RAM to put a logbook in, this can be replicated in the background to disk if needed
That is not a solution, that’s a workaround. Furhtermore I’ve already restricted it to the point of it being unusable.
I’ve given up on exclusions, and working with inclusions now, and not even our automations are logged.
These are my restrictions, but I still see stupid entries like sun… and time… which are of no use at all, except in specific debuggin states, and if you want to react on ‘golden hour’ or something like that.
There should be a default filter setup that is adequate and not slow as melasses, and then you can add more items to be logged if you need to and with the risk of it being slow as s…
I’ve started over with db’s twice, as they just grew (despite the purge settings).
I have to specifically exclude sun and time stuff (which I’ve done of course).
The logbook is a reflection of my testing, and moving the settings to the recorder
recorder:
purge_keep_days: 4
purge_interval: 3
include:
domains:
- light
- switch
- person
- sensor
entities:
- binary_sensor.remote_ui
- cover.garage_door
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
and I never see history data for sun.sun (or anything not in that list)
This is not relevant to the feature request of course, but is it possible to exclude with patterns. All my ESPHOME entities reports ssid, uptime, voltage, wifi signal, esphome version, ip etc., it would be great to exclude by something like sensor.*_uptime
I have reduced my logbook loading time to low single digit seconds (however, it does need some time to warm up in the background after each restart). Other people seeing similar results would be a success.
Let me make it more user friendly and get back, hopefully tonight or tomorrow.
Hi Amelchio, wow that made the logbook usable, it seems to work perfectly so far.
You are right about the first time lookup, that takes some extra time, but subsequently it helps a LOT.
I also struggle with history, logbook, and recorder. It would be useful if we could offload those to an external USB drive or USB thumb drive. This would save the SD.
Filtering by wildcard would also be awesome!
One additional request: specifying history and recorder below default_config should override the default config. Below is my config:
date, last boot, time, yr_symbol.
I’d like to remove all of them to keep the database to a minimum. This will speed up making snapshots and they will be much smaller.
As you can boot from USB drives now it doesn’t make sense to only move the db. You can flash an SSD and move the entire thing off of SD.
(Though we are still waiting for boot support from the pi foundation for the pi4)
