BHT-002 Thermostat with new tuya integration
I have migrated a HA system (2022.3.7) to talk to my underfloor heating control thermostat using the new tuya integration.
Service calls turn it on and off fine but the climate entity state and attributes do not get updated and as a result the lovelace climate card shows the wrong info.
I have another HA system with the old integration which shows the climate state and attributes correctly.
Any suggestions?
Debug log below…
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2022.3.7",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.9.9",
    "docker": true,
    "arch": "aarch64",
    "timezone": "Australia/Sydney",
    "os_name": "Linux",
    "os_version": "5.10.92-v8",
    "supervisor": "2022.03.5",
    "host_os": "Home Assistant OS 7.4",
    "docker_version": "20.10.9",
    "chassis": "embedded",
    "run_as_root": true
  "custom_components": {
    "ical": {
      "version": "1.3",
      "requirements": [
        "icalendar==4.0.7"
    "sonoff": {
      "version": "v2.4.6",
      "requirements": [
        "pycryptodome>=3.6.6"
    "rental_control": {
      "version": "v0.5.7",
      "requirements": [
        "icalendar==4.0.7"
    "iphonedetect": {
      "version": "1.4.0",
      "requirements": []
    "hacs": {
      "version": "1.24.0",
      "requirements": [
        "aiogithubapi>=21.11.0"
    "samsungtv_smart": {
      "version": "0.6.2",
      "requirements": [
        "websocket-client>=0.58.0",
        "wakeonlan>=2.0.0",
        "aiofiles>=0.8.0"
    "powercalc": {
      "version": "v0.19.3",
      "requirements": [
        "numpy>=1.21.1"
    "bureau_of_meteorology": {
      "version": "0.10.3",
      "requirements": []
    "favicon": {
      "version": "10.4",
      "requirements": []
    "willyweather": {
      "version": "1.5.3",
      "requirements": []
    "auto_backup": {
      "version": "0.10.1",
      "requirements": []
    "pijuice": {
      "version": "1.2.0",
      "requirements": [
        "smbus2==0.4.1"
  "integration_manifest": {
    "domain": "tuya",
    "name": "Tuya",
    "documentation": "https://www.home-assistant.io/integrations/tuya",
    "requirements": [
      "tuya-iot-py-sdk==0.6.6"
    "dependencies": [
      "ffmpeg"
    "codeowners": [
      "@Tuya",
      "@zlinoliver",
      "@METISU",
      "@frenck"
    "config_flow": true,
    "iot_class": "cloud_push",
    "dhcp": [
        "macaddress": "105A17*"
        "macaddress": "10D561*"
        "macaddress": "1869D8*"
        "macaddress": "381F8D*"
        "macaddress": "508A06*"
        "macaddress": "68572D*"
        "macaddress": "708976*"
        "macaddress": "7CF666*"
        "macaddress": "84E342*"
        "macaddress": "D4A651*"
        "macaddress": "D81F12*"
    "loggers": [
      "tuya_iot"
    "is_built_in": true
  "data": {
    "endpoint": "https://openapi.tuyaeu.com",
    "auth_type": 0,
    "country_code": "61",
    "app_type": "smartlife",
    "mqtt_connected": true,
    "disabled_by": null,
    "disabled_polling": false,
    "name": "WTS ensuite",
    "model": "",
    "category": "wk",
    "product_id": "IAYz2WK1th0cMLmL",
    "product_name": "thermostat",
    "online": true,
    "sub": false,
    "time_zone": "+00:00",
    "active_time": "2020-03-10T09:33:21+00:00",
    "create_time": "2020-03-07T14:19:51+00:00",
    "update_time": "2021-12-21T01:55:36+00:00",
    "function": {
      "switch": {
        "type": "Boolean",
        "value": {}
      "child_lock": {
        "type": "Boolean",
        "value": {}
      "temp_set": {
        "type": "Integer",
        "value": {
          "unit": "\u2103",
          "min": 10,
          "max": 70,
          "scale": 1,
          "step": 5
      "eco": {
        "type": "Boolean",
        "value": {}
      "upper_temp": {
        "type": "Integer",
        "value": {
          "unit": "\u2103",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 5
    "status_range": {
      "eco": {
        "type": "Boolean",
        "value": {}
      "temp_set": {
        "type": "Integer",
        "value": {
          "unit": "\u2103",
          "min": 10,
          "max": 70,
          "scale": 1,
          "step": 5
      "switch": {
        "type": "Boolean",
        "value": {}
      "child_lock": {
        "type": "Boolean",
        "value": {}
      "upper_temp": {
        "type": "Integer",
        "value": {
          "unit": "\u2103",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 5
    "status": {
      "switch": true,
      "temp_set": 48,
      "upper_temp": 39,
      "eco": false,
      "child_lock": false
    "home_assistant": {
      "name_by_user": null,
      "disabled": false,
      "entities": [
          "disabled": false,
          "entity_category": null,
          "device_class": null,
          "original_device_class": null,
          "icon": null,
          "original_icon": null,
          "unit_of_measurement": null,
          "state": {
            "entity_id": "climate.wts_ensuite",
            "state": "heat_cool",
            "attributes": {
              "hvac_modes": [
                "off",
                "heat_cool"
              "min_temp": 5.0,
              "max_temp": 35.0,
              "target_temp_step": 0.5,
              "current_temperature": 19.5,
              "temperature": 24.0,
              "friendly_name": "WTS ensuite",
              "supported_features": 1
            "last_changed": "2022-03-30T07:19:35.197454+00:00",
            "last_updated": "2022-03-30T07:19:35.197454+00:00"
