I need help with an automation.
In my bathroom I have the folowing:
- Regular Ceiling Lights
- One Led Strip (SONOFF L2)
- A smart Shelly relay and a Motion Sensor.
I already have the folowing automation for the ceiling lights
When there is movement, ceiling lights TURN ON, without Movement (after 1mn) ceiling lights TURN OFF
So far so good.
After some remodling I´ve added niche in my bathroom with the LED strip that I´ve mentioned.
Everything is already integrated in HA
I want the following:
When TIME = 20:00 LED StripTURNS ON
When TIME = 00:00 LED Strip TURNS OFF
CONDITION
IF MOTION is detected AND it’s 21:00 for example… Then LED Strip must remain ON and should not turn OFF when MOTION is not detected after 1mn
ALSO
IF it´s not between 20:00 and 00:00, let’s say 18:30… the LED Strip must also turn ON in conjuction with the ceiling lights… Then again when there is NO MOTION it should TURN OFF again AFTER 1mn
Some EDIT might be needed for spelling grammar.
