When you can use var values, then you can usually also use normal color definitions, like orange, black, white and so on, and maybe also RGB colors, like #FF00FF
You are using the CSS values when you write var()
Just write orange only
Var() values can be used to get the values HA use as standard and these values might also change when changing themes, so if you use these then you colours will change when HA theme is changed.
