Big Timer advice - which output to use?
Hi there.
I am trying to use Big Timer to turn a light on at dusk and then on at sunrise.
I have a switch with “On”(turning the light on) and “Off”(turning the light off).
  1. Which out put, from Big Timer, should I connect to the switch node - the first or the third?
  2. Should “On” be typed into the On Message box or the On Text box?
1st output
Great - thank you.
Now I know the correct output, shall do a bit more testing.
I also realised that there is a box to have big timer send the command every minute - this is on by default, so have turned that off.
