Binance Pool component
Hello, all
Glad to introduce component for integration with Binance Pool.
Project originally was forked from GitHub - drinfernoo/homeassistant-binance: Home Assistant integration for retrieving account balances and exchange rates from Binance
Now, component provide sensors for
  • Balance,
  • Currency exchange
  • Pool estimate profit and earnings
  • Workers health and hashrate
Welcome!
thank you very much for this addon
it is great to see it expanding with new sensors and options
but I have a problem setting it up, I get the following errors:
Unable to prepare setup for platform binance_pool.sensor: Unable to set up component.
Error during setup of component binance_pool
  File "/usr/src/homeassistant/homeassistant/setup.py", line 229, in _async_setup_component
    result = await task
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/config/custom_components/binance_pool/__init__.py", line 112, in setup
    invactive += 1
UnboundLocalError: local variable 'invactive' referenced before assignment
I have configured the binance domain to com
domain: com
is that ok?
Hello.
I fixed this now.
If You using hass - pls, reload or update component
Hello. Thank for great component!
Is it possible to get FUNDING_WALLET value from Binance? As i can see, btc_balance sensor gets SPOT_WALLET value only.
Hello, in last release.
New sensors for Funding wallet has been added.
Sensors automatically created for same coins as for spot wallet
Hello.
Since HA received Septembers update Binance pool isn`t working:(
Can not confirm. Which version of component You use?
Be sure, You have latest release (v2.0.56)
Please, check documentation for this version.
Yes, i`m having this version installed in HACS. Also i noticed i can install it on integrations in HA. in all cases problem is:
“Config entry ‘Binance’ for binance_pool integration not ready yet; Retrying in background”
Could You open issue on Issues · shammysha/homeassistant-binance-pool · GitHub?
Please, enable debug for binance_pool component in configuration.yaml …
logger:
  logs:
    custom_components.binance_pool: debug
… and include debug log to the issue.
P.S. Does You fulle remove records about binance_pool from configuration.yaml before install integration via “Integrations” in HA?
