Binary sensor and 5V connected state
How to create a binary sensor that will show the 5V connection to the charger. (state on / off)
I would probably need a wiring diagram and a yaml code. Can you advise?
well thank you
What charger?
I have already solved this by connecting a 2N2222 transistor
emitter - ESP gpio D3
base - usb 5V DC
collector - usb GND
YAML
#POWER SENSOR
binary_sensor:
  - platform: gpio
    pin:
      number: D3
      inverted: true
    device_class: power
I hope you’re also using a current limiting resistor on the base, and that USB GND is the same as ESP GND.
Who knows, this thread has been a waste of time because the OP doesn’t give useful information.
