I have a binary_sensor that I use as a presence detector home/ away), I wish to transform it into a device_tracker, is it possible?
Currently I use the Sure (cat flap) which intergrates with HA and show if the cat is home or away. But it is not able to be added to a person card (so I can use in a minimalist dashboard)?
device_tracker.see service works, but its state doesn’t survive a reboot.
With a binary sensor you can use composite device tracker component, i’m using it since several months and it does its job really fine.
