I use a binary_sensor command_line to check if an app is running by scanning an ip address and a port.
This is my configuration.yaml :
- platform: command_line
unique_id: binary_sensor.plex_statut
command: /bin/bash -c "(echo > /dev/tcp/192.168.1.1/32400) > /dev/null 2>&1 && echo on || echo off"
device_class: connectivity
payload_on: on
payload_off: off
command_timeout: 15
scan_interval: 10
It is working great but i get a message saying i need to move my configuration from yaml because the next update will break it.
But where should i need to put it and can i keep the same code ?
Thanks !
