Hi Folks,
i would like to ask you for help with binary sensors for my heating valves. Valve have three way endstop where i am able to get change status from Open valve to Close valve or vice versa (i can use even just one contact from endstop). The end stop is connected to mcp23017. In code is also part with Cover control. If i make manual change (open to close or close to open) everything work fine. Even automation working fine but just while (random time from 1hour to 3hours) and then ESP just freez and binary sensotrs start switching from active to inactiv status. Logs from EPS works and i can see even data from temperature sensors, but i am not able to control ESP from HA and need reboot ESP. Could be cause with some interference? Valces are under 220V … power cable and data cable (not shielded) are adjacent. If somebody hade same issue or know how to help, i will be glad for any idea
thank you
ESP
esphome:
platform: ESP32
board: lolin_d32
i2c:
sda: 21
scl: 22
scan: True
mcp23017:
- id: 'mcp23017_hub'
address: 0x20
binary_sensor:
- platform: gpio
#endstop for heating bathroom ON status
pin:
mcp23xxx: mcp23017_hub
number: 12
mode: INPUT_PULLUP
- platform: gpio
#endstop for heating bathroom OFF status
pin:
number: 13
mode: INPUT_PULLUP
- platform: gpio
#endstop for heating kitchen ON status
pin:
number: 14
mode: INPUT_PULLUP
- platform: gpio
#endstop for heating kitchen OFF status
pin:
number: 15
mode: INPUT_PULLUP
cover:
- platform: endstop
#cover for bathroom
name: "Topeni Koupelna"
open_action:
- switch.turn_on: kohout_topeni_koupelna
open_duration: 15s
open_endstop: koncak_topeni_koupelna_ON
close_action:
close_duration: 15s
close_endstop: koncak_topeni_koupelna_OFF
stop_action:
# - switch.turn_off: kohout_topeni_koupelna
- delay: 1.5s
max_duration: 20s
automation
alias: test
description: test
- platform: time_pattern
minutes: /1
condition:
- condition: device
device_id: 4d7664d5c32040875cc882f7ffb3c548
domain: cover
entity_id: cover.topeni_koupelna
type: is_closed
- device_id: 4d7664d5c32040875cc882f7ffb3c548
domain: cover
type: open
mode: single
alias: test2
description: test2
minutes: /1
condition:
- condition: device
domain: cover
type: is_open
domain: cover
type: close
mode: single
result of blinking binary sensor from active to inactive status
