Hi there,
after updaeting Home assistant to 12.2023 my ESP Home Binary Sensor GPIO ist working anymore.
![image](https://community-assets.home-assistant.io/original/4X/a/e/3/ae35997d7b6585952cbbea5f2ed62a85f1095200.png)
ive been searchung about some breaking changes in ESP an HA but i cant figure out whats the main Problem.
eventually you can give me a hint.
thanks a lot.
tom_l
2
Check the entity_id of the sensor on the device page in Settings → Devices and Integrations → ESPHome. Has it had _2
appended to the end?
This happens occasionally, not sure why.
You should be able to delete the _2
from the entity id after a restart.
If that has not happened could you please share the binary sensor config from your esphome device yaml.
nope, there is no _2
![image](https://community-assets.home-assistant.io/original/4X/4/d/1/4d14a0ae110de65cb7a6bdbd338508383bcbad3e.png)
here is the .yaml
esphome:
platform: ESP8266
board: nodemcuv2
binary_sensor:
- platform: gpio
pin:
number: D1
mode: INPUT_PULLUP
inverted: false
- platform: wifi_signal
name: "Türklingel Wifi Signal"
update_interval: 120s
- platform: uptime
tom_l
4
It could be something to do with the ü
in
Though not if you have your wifi sensor working.
Try reloading the integration. Go to Devices & Services → click on the ESPHome card then find your device and reload it:
